I am trying to create a piston for presence that uses a array of global variables. However the problem is that I don’t thing that such an array type exists. I attempted to use an array of boolean’s set to the global variables, but that removes my trigger conditions if anything changes. I would be interested in any more elegant solutions (trying to make it simple for updates and such and robust such it does not fail to detect presence changes much).
I am trying to create a piston that does the following:
- Can use an array of global variables to track presence
- I have independent pistons for each memeber that has a “debuffer” attached to ensure the phone is really away or home (makes sure the presence did not toggle within the last 3 minutes before setting to a new state) and sets the value to a global variable
- I have an independent global variable for guests that is set via IFTTT
- If someone arrives or leaves home I would like a SMS message sent out (I can do this from the independent pistons if needed
- If someone arrives home first then a “return home” piston is called
- If someone is the last to leave then a “leaving home” piston is called
N/A - I don’t have the piston fully coded due to lack of knowledge
