I was wondering if you guys could help me create a piston that when I arrive home (presence sensor) that it is on a timer in other words when I arrive home I only want the action to execute for only five minutes after arriving home more specifically when I open a door I don’t want it to execute everytime I open the door, but only the first time I open the door after arriving home via presence sensor. How would I code it?
Presence sensor as a trigger not a condition
guxdude
What I do is create two pistons. One to set a global variable: @arrivedHome. The other to trigger every time the door opens.
Piston 1:
If presenceSensor changes to present then
set @arrivedHome=true
endif
Piston 2:
If door changes to open then
if @arrivedHome is true then
do something
set @arrivedHome = false
endif
endif
WCmore
Just to clarify a bit. SmartThings (and thereby webCoRE) is ‘Event’ based… so the piston monitoring the door’s contact will fire every time the door opens (or closes).
There is no way to prevent this.
But… as @guxdude mentions, we can program to direct the logic flow differently depending on other conditions.
