I have this piston. But was wondering if it is already built into webcore and I am just missing it… if not then this does work nicely rather than getting the degrees that you are heading using the [presence sensor:bearing] attribute
Presence sensor bearing built in functionality?
Ok. Off on mini vacation, going to be traveling 300 miles. Time to see if this presence thing works as expected. I have Setup “waypoints” along the way to text myself and wife my progress to the destination. Keep fingers crossed I wrote it correctly. Let you know the results when I get there…
On mobile so I can’t really play with the expression editor. But I would look through the attribute options of [webcore presence: attributes] and see what pops up. Your piston looks like it should work. Good luck
Well. I can safely say that if cell service is spotty, so is presence. 3G connection is unreliable. Second thing, if you are on a highway and you have a way point Setup make sure your arriving circle is “LARGE”. It seems that either the iPhone or webcore only checks for presence every 5 minutes or so. With that being said, if you are flying down the road, you will blow right through the geofence before the presence even updates.
Presence should be updating every 5 minutes OR significant change in location (Apple specifies this as greater than 500 meters) OR you enter/exit a geofence.
If your circles were on the highway then you might have gone through them too fast to have the updated location. When a geofence triggers it doesnt necessarily mean there will be an update to the GPS location.
I had the, set just off the highway, as I didn’t actually want to arrive. I just wanted to trip the arivingat fence. Like I said I may need to broaden the fence, in order for it to register it correctly
You could be right and just need to make the fence bigger. You were triggering off of the arrivingAt data point in your piston i presume?
No I was not I was bowin through them. I’m not sure what happened . I am on iOS 11.03. Just updated to that. But what I did notice is that my phone for some reason at some point got stuck on a gps location and never left it. I rebooted my phone and reinstalled webcore beta app and things “seem” ok now. Will be traveling home today and will check my locations again. I did some tinkering with the piston while I have been gone. So that may throw a we]reach into it. Time will tell. I will post my findings when I get home.
Ok. Home. Thanks for safe travel wishes. Pistons fired off without a hiccup, except where cell coverage is spotty. Weird thing is google maps could find me, and not webcore mobile.
On bug I did find was the speed attribute, reports incorrectly @ady624 It seems to be reporting metric speed not mph. I was driving 70mph and reported 106. I know there is an option fro either speed or speed(metric)Didn’t try imperial.
Here is my expression for setting the speed variable to pass via args
floor([Tom :speed]) ‘ Mph’
You are correct. I set default fences and worked ok. Problem I had was I dropped pin in wrong location and it never entere the fence
Thank you
