This code is from the examples on the webcore wiki, all I did was put in my phone and my name for the presence device and thats all. The code runs, and I thought it was getting home events, the last log entry is around 4:57pm which is around the time I got home today but the presence tile never updates and it doesn’t seem to be getting updates from my phone but it works in the smartthings app because it says I am currently home and when at school it said away so the ‘sensor’ works, but the piston doesn’t seem to be getting updates. The ‘presence device’ is listed in the dashboard so webcore knows about it.
when piston receives presence event from phone it should update the presence tile in the dashboard to home or something like that, definitely not ‘no event yet’
According to the author they made the code so that once it starts to run it would wait 8 minutes and then if no event had happened yet it would put up a tile in the dashboard to say that no event had been received yet. That part works but it never changes even though the piston seems to receive events from my phone. The phone is a samsung note 10+ if that matters, it shouldn’t.
9/9/2019, 7:13:29 PM +449ms
+0ms ╔Received event [My home].time = 1568074410308 with a delay of -860ms
+137ms ║RunTime Analysis CS > 34ms > PS > 42ms > PE > 61ms > CE
+140ms ║Runtime (59097 bytes) successfully initialized in 42ms (v0.3.10f.20190822) (139ms)
+141ms ║╔Execution stage started
+181ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+210ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+212ms ║║Condition #241 evaluated true (6ms)
+213ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+215ms ║║Cancelling statement #239’s schedules…
+222ms ║║Executed virtual command setVariable (4ms)
+225ms ║║Cancelling statement #242’s schedules…
+231ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+236ms ║║Executed virtual command setVariable (3ms)
+263ms ║║Calculating (string) Home == (string) >> (boolean) false
+272ms ║║Calculating (string) Home == (string) >> (boolean) false
+283ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+294ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+321ms ║║Calculating (string) present == (string) present >> (boolean) true
+332ms ║║Executed virtual command setTile (4ms)
+337ms ║║Cancelling statement #213’s schedules…
+345ms ║║Executed virtual command setVariable (4ms)
+357ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+364ms ║║Cancelling statement #216’s schedules…
+371ms ║║Executed virtual command clearTile (3ms)
+379ms ║╚Execution stage complete. (238ms)
+382ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 7:21:30 PM CDT (in 480.478s)
+390ms ╚Event processed successfully (391ms)
9/9/2019, 7:05:29 PM +118ms
+1ms ╔Received event [My home].time = 1568073930308 with a delay of -1190ms
+182ms ║RunTime Analysis CS > 55ms > PS > 49ms > PE > 78ms > CE
+186ms ║Runtime (59098 bytes) successfully initialized in 49ms (v0.3.10f.20190822) (184ms)
+187ms ║╔Execution stage started
+212ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+238ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+240ms ║║Condition #241 evaluated true (8ms)
+241ms ║║Condition group #238 evaluated true (state did not change) (10ms)
+243ms ║║Cancelling statement #239’s schedules…
+250ms ║║Executed virtual command setVariable (4ms)
+253ms ║║Cancelling statement #242’s schedules…
+258ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+264ms ║║Executed virtual command setVariable (4ms)
+293ms ║║Calculating (string) Home == (string) >> (boolean) false
+301ms ║║Calculating (string) Home == (string) >> (boolean) false
+309ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+318ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+335ms ║║Calculating (string) present == (string) present >> (boolean) true
+341ms ║║Executed virtual command setTile (2ms)
+344ms ║║Cancelling statement #213’s schedules…
+350ms ║║Executed virtual command setVariable (2ms)
+358ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+363ms ║║Cancelling statement #216’s schedules…
+367ms ║║Executed virtual command clearTile (0ms)
+373ms ║╚Execution stage complete. (187ms)
+375ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 7:13:30 PM CDT (in 480.816s)
+383ms ╚Event processed successfully (383ms)
9/9/2019, 6:57:29 PM +140ms
+1ms ╔Received event [My home].time = 1568073450308 with a delay of -1168ms
+130ms ║RunTime Analysis CS > 28ms > PS > 39ms > PE > 63ms > CE
+133ms ║Runtime (59098 bytes) successfully initialized in 39ms (v0.3.10f.20190822) (131ms)
+135ms ║╔Execution stage started
+159ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+180ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+182ms ║║Condition #241 evaluated true (5ms)
+183ms ║║Condition group #238 evaluated true (state did not change) (6ms)
+185ms ║║Cancelling statement #239’s schedules…
+191ms ║║Executed virtual command setVariable (2ms)
+194ms ║║Cancelling statement #242’s schedules…
+198ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+202ms ║║Executed virtual command setVariable (2ms)
+233ms ║║Calculating (string) Home == (string) >> (boolean) false
+241ms ║║Calculating (string) Home == (string) >> (boolean) false
+248ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+256ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+273ms ║║Calculating (string) present == (string) present >> (boolean) true
+278ms ║║Executed virtual command setTile (2ms)
+281ms ║║Cancelling statement #213’s schedules…
+286ms ║║Executed virtual command setVariable (2ms)
+294ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+298ms ║║Cancelling statement #216’s schedules…
+302ms ║║Executed virtual command clearTile (1ms)
+307ms ║╚Execution stage complete. (173ms)
+309ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 7:05:30 PM CDT (in 480.86s)
+318ms ╚Event processed successfully (317ms)
9/9/2019, 6:49:29 PM +232ms
+0ms ╔Received event [My home].time = 1568072970308 with a delay of -1077ms
+154ms ║RunTime Analysis CS > 34ms > PS > 52ms > PE > 69ms > CE
+158ms ║Runtime (59098 bytes) successfully initialized in 52ms (v0.3.10f.20190822) (156ms)
+182ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+203ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+205ms ║║Condition #241 evaluated true (6ms)
+206ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+208ms ║║Cancelling statement #239’s schedules…
+215ms ║║Executed virtual command setVariable (3ms)
+218ms ║║Cancelling statement #242’s schedules…
+222ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+227ms ║║Executed virtual command setVariable (3ms)
+253ms ║║Calculating (string) Home == (string) >> (boolean) false
+261ms ║║Calculating (string) Home == (string) >> (boolean) false
+268ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+277ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+293ms ║║Calculating (string) present == (string) present >> (boolean) true
+298ms ║║Executed virtual command setTile (1ms)
+301ms ║║Cancelling statement #213’s schedules…
+306ms ║║Executed virtual command setVariable (3ms)
+314ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+318ms ║║Cancelling statement #216’s schedules…
+323ms ║║Executed virtual command clearTile (1ms)
+328ms ║╚Execution stage complete. (170ms)
+329ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:57:30 PM CDT (in 480.747s)
+338ms ╚Event processed successfully (339ms)
9/9/2019, 6:41:29 PM +120ms
+1ms ╔Received event [My home].time = 1568072490308 with a delay of -1188ms
+287ms ║RunTime Analysis CS > 176ms > PS > 42ms > PE > 68ms > CE
+291ms ║Runtime (59099 bytes) successfully initialized in 42ms (v0.3.10f.20190822) (287ms)
+292ms ║╔Execution stage started
+325ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+346ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+348ms ║║Condition #241 evaluated true (5ms)
+349ms ║║Condition group #238 evaluated true (state did not change) (7ms)
+351ms ║║Cancelling statement #239’s schedules…
+358ms ║║Executed virtual command setVariable (3ms)
+361ms ║║Cancelling statement #242’s schedules…
+366ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+370ms ║║Executed virtual command setVariable (3ms)
+398ms ║║Calculating (string) Home == (string) >> (boolean) false
+406ms ║║Calculating (string) Home == (string) >> (boolean) false
+413ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+421ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+437ms ║║Calculating (string) present == (string) present >> (boolean) true
+442ms ║║Executed virtual command setTile (1ms)
+445ms ║║Cancelling statement #213’s schedules…
+451ms ║║Executed virtual command setVariable (3ms)
+459ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+464ms ║║Cancelling statement #216’s schedules…
+468ms ║║Executed virtual command clearTile (1ms)
+474ms ║╚Execution stage complete. (182ms)
+475ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:49:30 PM CDT (in 480.714s)
+483ms ╚Event processed successfully (482ms)
9/9/2019, 6:33:29 PM +143ms
+0ms ╔Received event [My home].time = 1568072010308 with a delay of -1165ms
+134ms ║RunTime Analysis CS > 23ms > PS > 48ms > PE > 63ms > CE
+138ms ║Runtime (59098 bytes) successfully initialized in 48ms (v0.3.10f.20190822) (137ms)
+170ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+190ms ║║Comparison (boolean) false is_not (boolean) true = true (1ms)
+192ms ║║Condition #241 evaluated true (6ms)
+193ms ║║Condition group #238 evaluated true (state did not change) (7ms)
+195ms ║║Cancelling statement #239’s schedules…
+201ms ║║Executed virtual command setVariable (3ms)
+204ms ║║Cancelling statement #242’s schedules…
+209ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+213ms ║║Executed virtual command setVariable (3ms)
+239ms ║║Calculating (string) Home == (string) >> (boolean) false
+246ms ║║Calculating (string) Home == (string) >> (boolean) false
+254ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+262ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+279ms ║║Calculating (string) present == (string) present >> (boolean) true
+285ms ║║Executed virtual command setTile (2ms)
+288ms ║║Cancelling statement #213’s schedules…
+294ms ║║Executed virtual command setVariable (2ms)
+301ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+306ms ║║Cancelling statement #216’s schedules…
+309ms ║║Executed virtual command clearTile (1ms)
+315ms ║╚Execution stage complete. (176ms)
+317ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:41:30 PM CDT (in 480.849s)
+325ms ╚Event processed successfully (325ms)
9/9/2019, 6:25:29 PM +117ms
+0ms ╔Received event [My home].time = 1568071530308 with a delay of -1192ms
+201ms ║RunTime Analysis CS > 39ms > PS > 77ms > PE > 86ms > CE
+205ms ║Runtime (59097 bytes) successfully initialized in 77ms (v0.3.10f.20190822) (203ms)
+206ms ║╔Execution stage started
+231ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+253ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+255ms ║║Condition #241 evaluated true (5ms)
+256ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+258ms ║║Cancelling statement #239’s schedules…
+266ms ║║Executed virtual command setVariable (5ms)
+269ms ║║Cancelling statement #242’s schedules…
+274ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+279ms ║║Executed virtual command setVariable (3ms)
+308ms ║║Calculating (string) Home == (string) >> (boolean) false
+317ms ║║Calculating (string) Home == (string) >> (boolean) false
+325ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+334ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+351ms ║║Calculating (string) present == (string) present >> (boolean) true
+356ms ║║Executed virtual command setTile (1ms)
+360ms ║║Cancelling statement #213’s schedules…
+368ms ║║Executed virtual command setVariable (6ms)
+377ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+382ms ║║Cancelling statement #216’s schedules…
+386ms ║║Executed virtual command clearTile (1ms)
+392ms ║╚Execution stage complete. (187ms)
+393ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:33:30 PM CDT (in 480.798s)
+400ms ╚Event processed successfully (400ms)
9/9/2019, 6:17:30 PM +369ms
+2ms ╔Received event [My home].time = 1568071050308 with a delay of 60ms
+203ms ║RunTime Analysis CS > 40ms > PS > 76ms > PE > 88ms > CE
+207ms ║Runtime (59094 bytes) successfully initialized in 76ms (v0.3.10f.20190822) (202ms)
+208ms ║╔Execution stage started
+304ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+363ms ║║Comparison (boolean) false is_not (boolean) true = true (3ms)
+365ms ║║Condition #241 evaluated true (10ms)
+366ms ║║Condition group #238 evaluated true (state did not change) (11ms)
+369ms ║║Cancelling statement #239’s schedules…
+376ms ║║Executed virtual command setVariable (3ms)
+380ms ║║Cancelling statement #242’s schedules…
+385ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+389ms ║║Executed virtual command setVariable (3ms)
+418ms ║║Calculating (string) Home == (string) >> (boolean) false
+426ms ║║Calculating (string) Home == (string) >> (boolean) false
+434ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+443ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+460ms ║║Calculating (string) present == (string) present >> (boolean) true
+466ms ║║Executed virtual command setTile (2ms)
+470ms ║║Cancelling statement #213’s schedules…
+475ms ║║Executed virtual command setVariable (3ms)
+483ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+489ms ║║Cancelling statement #216’s schedules…
+492ms ║║Executed virtual command clearTile (1ms)
+520ms ║╚Execution stage complete. (312ms)
+542ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:25:30 PM CDT (in 479.398s)
+551ms ╚Event processed successfully (550ms)
9/9/2019, 6:09:29 PM +104ms
+0ms ╔Received event [My home].time = 1568070570308 with a delay of -1204ms
+140ms ║RunTime Analysis CS > 30ms > PS > 45ms > PE > 64ms > CE
+144ms ║Runtime (59098 bytes) successfully initialized in 45ms (v0.3.10f.20190822) (143ms)
+146ms ║╔Execution stage started
+192ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+216ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+218ms ║║Condition #241 evaluated true (5ms)
+219ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+221ms ║║Cancelling statement #239’s schedules…
+228ms ║║Executed virtual command setVariable (4ms)
+231ms ║║Cancelling statement #242’s schedules…
+236ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+241ms ║║Executed virtual command setVariable (3ms)
+267ms ║║Calculating (string) Home == (string) >> (boolean) false
+275ms ║║Calculating (string) Home == (string) >> (boolean) false
+282ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+291ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+308ms ║║Calculating (string) present == (string) present >> (boolean) true
+314ms ║║Executed virtual command setTile (2ms)
+317ms ║║Cancelling statement #213’s schedules…
+322ms ║║Executed virtual command setVariable (2ms)
+330ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+336ms ║║Cancelling statement #216’s schedules…
+340ms ║║Executed virtual command clearTile (1ms)
+346ms ║╚Execution stage complete. (200ms)
+347ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:17:30 PM CDT (in 480.857s)
+356ms ╚Event processed successfully (356ms)
9/9/2019, 6:01:29 PM +138ms
+0ms ╔Received event [My home].time = 1568070090308 with a delay of -1171ms
+158ms ║RunTime Analysis CS > 35ms > PS > 52ms > PE > 72ms > CE
+161ms ║Runtime (59098 bytes) successfully initialized in 52ms (v0.3.10f.20190822) (160ms)
+162ms ║╔Execution stage started
+188ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+223ms ║║Executed virtual command setVariable (3ms)
+226ms ║║Cancelling statement #242’s schedules…
+237ms ║║Executed virtual command setVariable (4ms)
+266ms ║║Calculating (string) Home == (string) >> (boolean) false
+276ms ║║Calculating (string) Home == (string) >> (boolean) false
+310ms ║║Calculating (string) present == (string) present >> (boolean) true
+316ms ║║Executed virtual command setTile (1ms)
+319ms ║║Cancelling statement #213’s schedules…
+326ms ║║Executed virtual command setVariable (4ms)
+336ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+341ms ║║Cancelling statement #216’s schedules…
+345ms ║║Executed virtual command clearTile (0ms)
+351ms ║╚Execution stage complete. (189ms)
+352ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:09:30 PM CDT (in 480.818s)
+360ms ╚Event processed successfully (361ms)
9/9/2019, 5:53:30 PM +615ms
+1ms ╔Received event [My home].time = 1568069610308 with a delay of 305ms
+1383ms ║RunTime Analysis CS > 1234ms > PS > 68ms > PE > 83ms > CE
+1387ms ║Runtime (59099 bytes) successfully initialized in 68ms (v0.3.10f.20190822) (1383ms)
+1388ms ║╔Execution stage started
+1465ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1532ms ║║Comparison (boolean) false is_not (boolean) true = true (4ms)
+1535ms ║║Condition #241 evaluated true (12ms)
+1537ms ║║Condition group #238 evaluated true (state did not change) (14ms)
+1540ms ║║Cancelling statement #239’s schedules…
+1549ms ║║Executed virtual command setVariable (5ms)
+1554ms ║║Cancelling statement #242’s schedules…
+1559ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+1565ms ║║Executed virtual command setVariable (3ms)
+1597ms ║║Calculating (string) Home == (string) >> (boolean) false
+1605ms ║║Calculating (string) Home == (string) >> (boolean) false
+1612ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+1622ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+1639ms ║║Calculating (string) present == (string) present >> (boolean) true
+1645ms ║║Executed virtual command setTile (2ms)
+1648ms ║║Cancelling statement #213’s schedules…
+1654ms ║║Executed virtual command setVariable (3ms)
+1662ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1668ms ║║Cancelling statement #216’s schedules…
+1671ms ║║Executed virtual command clearTile (1ms)
+1701ms ║╚Execution stage complete. (313ms)
+1725ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 6:01:30 PM CDT (in 477.97s)
+1734ms ╚Event processed successfully (1734ms)
9/9/2019, 5:45:29 PM +222ms
+1ms ╔Received event [My home].time = 1568069130308 with a delay of -1086ms
+146ms ║RunTime Analysis CS > 23ms > PS > 54ms > PE > 69ms > CE
+150ms ║Runtime (59098 bytes) successfully initialized in 54ms (v0.3.10f.20190822) (147ms)
+151ms ║╔Execution stage started
+175ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+196ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+198ms ║║Condition #241 evaluated true (6ms)
+199ms ║║Condition group #238 evaluated true (state did not change) (7ms)
+201ms ║║Cancelling statement #239’s schedules…
+208ms ║║Executed virtual command setVariable (5ms)
+213ms ║║Cancelling statement #242’s schedules…
+217ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+248ms ║║Calculating (string) Home == (string) >> (boolean) false
+257ms ║║Calculating (string) Home == (string) >> (boolean) false
+264ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+272ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+289ms ║║Calculating (string) present == (string) present >> (boolean) true
+294ms ║║Executed virtual command setTile (1ms)
+297ms ║║Cancelling statement #213’s schedules…
+303ms ║║Executed virtual command setVariable (3ms)
+311ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+315ms ║║Cancelling statement #216’s schedules…
+319ms ║║Executed virtual command clearTile (0ms)
+324ms ║╚Execution stage complete. (174ms)
+325ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:53:30 PM CDT (in 480.761s)
+334ms ╚Event processed successfully (334ms)
9/9/2019, 5:37:29 PM +141ms
+0ms ╔Received event [My home].time = 1568068650308 with a delay of -1168ms
+124ms ║RunTime Analysis CS > 30ms > PS > 34ms > PE > 60ms > CE
+127ms ║Runtime (59098 bytes) successfully initialized in 34ms (v0.3.10f.20190822) (126ms)
+128ms ║╔Execution stage started
+156ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+177ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+178ms ║║Condition #241 evaluated true (5ms)
+180ms ║║Condition group #238 evaluated true (state did not change) (7ms)
+182ms ║║Cancelling statement #239’s schedules…
+188ms ║║Executed virtual command setVariable (3ms)
+192ms ║║Cancelling statement #242’s schedules…
+196ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+200ms ║║Executed virtual command setVariable (2ms)
+226ms ║║Calculating (string) Home == (string) >> (boolean) false
+234ms ║║Calculating (string) Home == (string) >> (boolean) false
+241ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+249ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+265ms ║║Calculating (string) present == (string) present >> (boolean) true
+270ms ║║Executed virtual command setTile (1ms)
+273ms ║║Cancelling statement #213’s schedules…
+288ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+293ms ║║Cancelling statement #216’s schedules…
+296ms ║║Executed virtual command clearTile (0ms)
+302ms ║╚Execution stage complete. (174ms)
+303ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:45:30 PM CDT (in 480.864s)
+312ms ╚Event processed successfully (312ms)
9/9/2019, 5:29:29 PM +116ms
+1ms ╔Received event [My home].time = 1568068170308 with a delay of -1192ms
+136ms ║RunTime Analysis CS > 20ms > PS > 41ms > PE > 75ms > CE
+140ms ║Runtime (59098 bytes) successfully initialized in 41ms (v0.3.10f.20190822) (138ms)
+165ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+187ms ║║Comparison (boolean) false is_not (boolean) true = true (1ms)
+188ms ║║Condition #241 evaluated true (7ms)
+189ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+191ms ║║Cancelling statement #239’s schedules…
+198ms ║║Executed virtual command setVariable (3ms)
+201ms ║║Cancelling statement #242’s schedules…
+206ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+211ms ║║Executed virtual command setVariable (3ms)
+237ms ║║Calculating (string) Home == (string) >> (boolean) false
+244ms ║║Calculating (string) Home == (string) >> (boolean) false
+250ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+258ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+275ms ║║Calculating (string) present == (string) present >> (boolean) true
+280ms ║║Executed virtual command setTile (1ms)
+283ms ║║Cancelling statement #213’s schedules…
+288ms ║║Executed virtual command setVariable (3ms)
+296ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+300ms ║║Cancelling statement #216’s schedules…
+303ms ║║Executed virtual command clearTile (0ms)
+309ms ║╚Execution stage complete. (169ms)
+310ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:37:30 PM CDT (in 480.883s)
+321ms ╚Event processed successfully (321ms)
9/9/2019, 5:21:29 PM +141ms
+0ms ╔Received event [My home].time = 1568067690308 with a delay of -1167ms
+149ms ║RunTime Analysis CS > 34ms > PS > 45ms > PE > 69ms > CE
+152ms ║Runtime (59098 bytes) successfully initialized in 45ms (v0.3.10f.20190822) (151ms)
+153ms ║╔Execution stage started
+179ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+201ms ║║Comparison (boolean) false is_not (boolean) true = true (1ms)
+202ms ║║Condition #241 evaluated true (6ms)
+203ms ║║Condition group #238 evaluated true (state did not change) (7ms)
+206ms ║║Cancelling statement #239’s schedules…
+212ms ║║Executed virtual command setVariable (4ms)
+216ms ║║Cancelling statement #242’s schedules…
+221ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+225ms ║║Executed virtual command setVariable (2ms)
+255ms ║║Calculating (string) Home == (string) >> (boolean) false
+265ms ║║Calculating (string) Home == (string) >> (boolean) false
+272ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+281ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+299ms ║║Calculating (string) present == (string) present >> (boolean) true
+305ms ║║Executed virtual command setTile (2ms)
+308ms ║║Cancelling statement #213’s schedules…
+314ms ║║Executed virtual command setVariable (3ms)
+323ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+328ms ║║Cancelling statement #216’s schedules…
+332ms ║║Executed virtual command clearTile (0ms)
+337ms ║╚Execution stage complete. (184ms)
+339ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:29:30 PM CDT (in 480.829s)
+347ms ╚Event processed successfully (347ms)
9/9/2019, 5:13:29 PM +75ms
+0ms ╔Received event [My home].time = 1568067210308 with a delay of -1233ms
+161ms ║RunTime Analysis CS > 24ms > PS > 60ms > PE > 76ms > CE
+165ms ║Runtime (59098 bytes) successfully initialized in 60ms (v0.3.10f.20190822) (164ms)
+217ms ║║Comparison (boolean) false is_not (boolean) true = true (1ms)
+220ms ║║Condition #241 evaluated true (6ms)
+221ms ║║Condition group #238 evaluated true (state did not change) (10ms)
+224ms ║║Cancelling statement #239’s schedules…
+233ms ║║Executed virtual command setVariable (4ms)
+237ms ║║Cancelling statement #242’s schedules…
+244ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+250ms ║║Executed virtual command setVariable (2ms)
+287ms ║║Calculating (string) Home == (string) >> (boolean) false
+295ms ║║Calculating (string) Home == (string) >> (boolean) false
+302ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+311ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+329ms ║║Calculating (string) present == (string) present >> (boolean) true
+334ms ║║Executed virtual command setTile (1ms)
+341ms ║║Executed virtual command setVariable (2ms)
+351ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+356ms ║║Cancelling statement #216’s schedules…
+360ms ║║Executed virtual command clearTile (1ms)
+367ms ║╚Execution stage complete. (199ms)
+368ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:21:30 PM CDT (in 480.865s)
+376ms ╚Event processed successfully (376ms)
9/9/2019, 5:05:29 PM +117ms
+1ms ╔Received event [My home].time = 1568066730308 with a delay of -1191ms
+176ms ║RunTime Analysis CS > 30ms > PS > 67ms > PE > 78ms > CE
+180ms ║Runtime (59098 bytes) successfully initialized in 67ms (v0.3.10f.20190822) (178ms)
+181ms ║╔Execution stage started
+211ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+236ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+238ms ║║Condition #241 evaluated true (7ms)
+239ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+242ms ║║Cancelling statement #239’s schedules…
+253ms ║║Executed virtual command setVariable (8ms)
+257ms ║║Cancelling statement #242’s schedules…
+262ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+270ms ║║Executed virtual command setVariable (6ms)
+304ms ║║Calculating (string) Home == (string) >> (boolean) false
+315ms ║║Calculating (string) Home == (string) >> (boolean) false
+338ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+361ms ║║Calculating (string) present == (string) present >> (boolean) true
+369ms ║║Executed virtual command setTile (2ms)
+374ms ║║Cancelling statement #213’s schedules…
+382ms ║║Executed virtual command setVariable (3ms)
+395ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+403ms ║║Cancelling statement #216’s schedules…
+409ms ║║Executed virtual command clearTile (1ms)
+418ms ║╚Execution stage complete. (237ms)
+420ms ║Setting up scheduled job for Mon, Sep 9 2019 @ 5:13:30 PM CDT (in 480.772s)
+430ms ╚Event processed successfully (430ms)
9/9/2019, 4:57:29 PM +138ms
+0ms ╔Received event [My home].time = 1568066250308 with a delay of -1170ms
+474ms ║RunTime Analysis CS > 194ms > PS > 228ms > PE > 52ms > CE
+478ms ║Runtime (59101 bytes) successfully initialized in 228ms (v0.3.10f.20190822) (477ms)
+479ms ║╔Execution stage started
+506ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+527ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms)
+529ms ║║Condition #241 evaluated true (5ms)
+530ms ║║Condition group #238 evaluated true (state did not change) (8ms)
+532ms ║║Cancelling statement #239’s schedules…
+538ms ║║Executed virtual command setVariable (3ms)
+541ms ║║Cancelling statement #242’s schedules…
+546ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+550ms ║║Executed virtual command setVariable (2ms)
+576ms ║║Calculating (string) Home == (string) >> (boolean) false
+584ms ║║Calculating (string) Home == (string) >> (boolean) false
+591ms ║║Calculating (enum) present == (enum) present >> (boolean) true
+600ms ║║Calculating (boolean) false == (boolean) false >> (boolean) true
+616ms ║║Calculating (string) present == (string) present >> (boolean) true
+622ms ║║Executed virtual command setTile (1ms)
+625ms ║║Cancelling statement #213’s schedules…
+630ms ║║Executed virtual command setVariable (3ms)
+638ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+643ms ║║Cancelling statement #216’s schedules…
+646ms ║║Executed virtual command clearTile (0ms)
