I get the error java.lang.NumberFormatException: For input string: “Graph” on line 2580 (method writeToFuelStream) when trying to append data to fuel stream. The fuel stream is never created.
Problem creating Fuel Stream
Are you on the latest webcore (I ask as the line numbers don’t match up). Please check that.
Then show the HE logs if the exception occurs as it will have more of the stack trace on where it happened.
HE console -> Logs
I am on the latest version v0.3.114.20220203 HE: v3.11420230103_HE - January 3, 2023
I initially created the Thermostat and weather fuel streams and they worked. When I tried to add the server ones it throws the error and doesn’t create the fuel stream. The log always looks like it writes the data but the fuel stream is not created.
From the Apps code
Webcore - Last update January 15, 2023 for Hubitat
Webcore Fuel Stream - Last update January 7, 2023 for Hubitat
Webcore Piston - Last update January 15, 2023 for Hubitat
Webcore Storage - Last update Noveber 16, 2022 for Hubitat
In HE console (where you see devices, apps, etc) on the left side there is ‘Logs’
If you have that open when you run something, it there was an exception it should show more information there.
also see these last 3 notes:
I’m familiar with the logs but I don’t see anything about an exception.
I did a soft reset but am still having the same issue.
So what is Fuel Steam - 15 Minute ?
It would be good to sort the columns of the app display by ‘Type’ and then show all of the
webCoRE Fuel Stream lines (copy all of the line)
So it looks like its name starts with a number…
or is it a LTS
please post the information I requested above.
None of this explains what is
Please post the data I requested.
it would be good to sort the columns of the app display by ‘Type’ and then show all of the webCoRE Fuel Stream lines (copy all of the line)
