Hi all
how do I get remove any of
Problem with if how to remove any of from a if?
beau76
eibyer
Edit the piston ID from your second screenshot.
Regarding ‘any of’, I think that will work as is even if there’s only one device in the variable, I don’t actually remember seeing that from older versions of webcore.
Edit: I guess ‘any of’ has always been there, just have not noticed it
orangebucket
A variable of type device can be set to a list of devices. The editor doesn’t know how you are going to use it so gives you the ‘any of’ or ‘all of’ options.
eibyer
Yeah, I don’t know what the reasoning is behind it but it works the same with one or more devices within the device variable.
