Problem with “Turn this switch on if another switch changes away from Off”
I have two pistons that aren’t working. I’m not sure but they may be related to the DLST issues. I am running version ofc of the app. Both of these switches, each of a different type, have worked for over a year with zero issues. I have a simple piston that says when dimmer A changes away from off set dimmer B to 15%. The piston also tells dimmer B to turn off when dimmer A turns off. The other switch is the same scenario but it turns on/off a smart outlet to mirror a GE simple light switch. I’ve edited them slightly to try and “poke” them back to life but no go. My garage isn’t triggering my mimo relay when my Android presence arrives but I need to make sure that’s not a different issue. That garage piston has been working very well for over a year too. I can’t tell from the forum here if other people with switch problems have found resolutions yet. Thanks all.
Update to version 0.2.0fd first. Then re-test your pistons. There were a couple of sets of fixes pushed out on 11/5/2017.
I ended up doing that and did indeed fix everythingMy app did not show an update was needed. My Github has not been showing updates needed either so I broke something when I mereged my SmartThings/Samsung accounts. I’ll tackle that later this week. Thanks for the info. It’s appreciated.
Glad to hear that worked out. After updating on my end, things have been quite stable again.
