Hello
I am having trouble with the wait element in a while loop:
I want to create a piston that monitors the state of a window and, if open,
executes an action every 5 minutes (in this case sends a message as a sample).
After querying that the window is open, I would like to use a while loop to check every 5
minutes whether the window is still open.To do this, I wrote a wait statement in the loop.
When opening the window for the first time, the message “Window open” appears
Every x-minutes the message “Window still open” appears
After closing, the message “Window closed” appears
The Piston runs error-free until the loop (outputs the message Window was opened at the beginning.
Everything in the loop is ignored - no message appears.
The message after the loop (window was closed) is displayed.
29.3.2021, 19:57:28 +959ms
+1ms ╔Received event [Fe Bad].threeAxis = [-995,-14,-13] with a delay of 53ms
+58ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 37ms > CE
+60ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (58ms)
+61ms ║╔Execution stage started
+68ms ║║Comparison (decimal) -995.0 rises_to_or_above (integer) 400 = false (1ms)
+69ms ║║Condition #2 evaluated false (4ms)
+70ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+75ms ║║Comparison (decimal) -995.0 drops_below (integer) 400 = false (1ms)
+77ms ║║Condition #15 evaluated false (4ms)
+77ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+79ms ║╚Execution stage complete. (18ms)
+80ms ╚Event processed successfully (80ms)
29.3.2021, 19:57:27 +936ms
+1ms ╔Received event [Fe Bad].threeAxis = [-990,-16,-8] with a delay of 47ms
+54ms ║RunTime Analysis CS > 15ms > PS > 4ms > PE > 35ms > CE
+56ms ║Runtime (38327 bytes) successfully initialized in 4ms (v0.3.113.20210203) (54ms)
+57ms ║╔Execution stage started
+64ms ║║Comparison (decimal) -990.0 rises_to_or_above (integer) 400 = false (1ms)
+65ms ║║Condition #2 evaluated false (4ms)
+66ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+71ms ║║Comparison (decimal) -990.0 drops_below (integer) 400 = false (1ms)
+73ms ║║Condition #15 evaluated false (4ms)
+73ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+75ms ║╚Execution stage complete. (18ms)
+76ms ╚Event processed successfully (76ms)
29.3.2021, 19:57:26 +983ms
+1ms ╔Received event [Fe Bad].threeAxis = [-986,-12,-12] with a delay of 56ms
+61ms ║RunTime Analysis CS > 19ms > PS > 4ms > PE > 38ms > CE
+64ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (61ms)
+64ms ║╔Execution stage started
+71ms ║║Comparison (decimal) -986.0 rises_to_or_above (integer) 400 = false (1ms)
+72ms ║║Condition #2 evaluated false (4ms)
+73ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+78ms ║║Comparison (decimal) -986.0 drops_below (integer) 400 = false (0ms)
+80ms ║║Condition #15 evaluated false (5ms)
+81ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+82ms ║╚Execution stage complete. (18ms)
+83ms ╚Event processed successfully (83ms)
29.3.2021, 19:57:25 +907ms
+1ms ╔Received event [Fe Bad].threeAxis = [-995,-11,-13] with a delay of 52ms
+60ms ║RunTime Analysis CS > 18ms > PS > 4ms > PE > 39ms > CE
+62ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (61ms)
+63ms ║╔Execution stage started
+70ms ║║Comparison (decimal) -995.0 rises_to_or_above (integer) 400 = false (1ms)
+78ms ║║Comparison (decimal) -995.0 drops_below (integer) 400 = false (1ms)
+79ms ║║Condition #15 evaluated false (4ms)
+80ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+82ms ║╚Execution stage complete. (19ms)
29.3.2021, 19:57:24 +885ms
+1ms ╔Received event [Fe Bad].threeAxis = [-969,-46,-73] with a delay of 46ms
+54ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 33ms > CE
+56ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (54ms)
+65ms ║║Comparison (decimal) -969.0 rises_to_or_above (integer) 400 = false (1ms)
+67ms ║║Condition #2 evaluated false (5ms)
+68ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+74ms ║║Comparison (decimal) -969.0 drops_below (integer) 400 = false (1ms)
+75ms ║║Condition #15 evaluated false (5ms)
+76ms ║║Condition group #14 evaluated false (state did not change) (6ms)
+78ms ║╚Execution stage complete. (21ms)
+79ms ╚Event processed successfully (79ms)
29.3.2021, 19:57:24 +397ms
+1ms ╔Received event [Fe Bad].threeAxis = [-988,-16,-13] with a delay of 52ms
+60ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 39ms > CE
+62ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (60ms)
+70ms ║║Comparison (decimal) -988.0 rises_to_or_above (integer) 400 = false (0ms)
+71ms ║║Condition #2 evaluated false (4ms)
+72ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+77ms ║║Comparison (decimal) -988.0 drops_below (integer) 400 = false (1ms)
+78ms ║║Condition #15 evaluated false (4ms)
+79ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+80ms ║╚Execution stage complete. (17ms)
+81ms ╚Event processed successfully (81ms)
29.3.2021, 19:57:23 +383ms
+1ms ╔Received event [Fe Bad].threeAxis = [-992,-17,-14] with a delay of 52ms
+50ms ║RunTime Analysis CS > 14ms > PS > 4ms > PE > 32ms > CE
+53ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (50ms)
+53ms ║╔Execution stage started
+60ms ║║Comparison (decimal) -992.0 rises_to_or_above (integer) 400 = false (1ms)
+62ms ║║Condition #2 evaluated false (5ms)
+63ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+68ms ║║Comparison (decimal) -992.0 drops_below (integer) 400 = false (1ms)
+69ms ║║Condition #15 evaluated false (4ms)
+70ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+72ms ║╚Execution stage complete. (18ms)
+73ms ╚Event processed successfully (73ms)
29.3.2021, 19:57:22 +465ms
+1ms ╔Received event [Fe Bad].threeAxis = [-993,-12,-13] with a delay of 44ms
+56ms ║RunTime Analysis CS > 15ms > PS > 3ms > PE > 37ms > CE
+58ms ║Runtime (38323 bytes) successfully initialized in 3ms (v0.3.113.20210203) (56ms)
+59ms ║╔Execution stage started
+67ms ║║Comparison (decimal) -993.0 rises_to_or_above (integer) 400 = false (1ms)
+68ms ║║Condition #2 evaluated false (5ms)
+69ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+75ms ║║Comparison (decimal) -993.0 drops_below (integer) 400 = false (1ms)
+76ms ║║Cancelling condition #15’s schedules…
+77ms ║║Condition #15 evaluated false (5ms)
+78ms ║║Cancelling condition #14’s schedules…
+79ms ║║Condition group #14 evaluated false (state changed) (7ms)
+81ms ║╚Execution stage complete. (22ms)
+82ms ╚Event processed successfully (82ms)
29.3.2021, 19:57:21 +376ms
+1ms ╔Received event [Fe Bad].threeAxis = [-994,-13,-14] with a delay of 44ms
+52ms ║RunTime Analysis CS > 15ms > PS > 4ms > PE > 32ms > CE
+54ms ║Runtime (38328 bytes) successfully initialized in 4ms (v0.3.113.20210203) (52ms)
+55ms ║╔Execution stage started
+62ms ║║Comparison (decimal) -994.0 rises_to_or_above (integer) 400 = false (0ms)
+64ms ║║Condition #2 evaluated false (5ms)
+65ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+71ms ║║Comparison (decimal) -994.0 drops_below (integer) 400 = true (0ms)
+72ms ║║Cancelling condition #15’s schedules…
+73ms ║║Condition #15 evaluated true (6ms)
+74ms ║║Cancelling condition #14’s schedules…
+75ms ║║Condition group #14 evaluated true (state changed) (8ms)
+77ms ║║Cancelling statement #16’s schedules…
+104ms ║║Executed virtual command sendPushNotification (24ms)
+107ms ║╚Execution stage complete. (52ms)
+108ms ╚Event processed successfully (108ms)
29.3.2021, 19:57:20 +371ms
+1ms ╔Received event [Fe Bad].threeAxis = [1056,84,199] with a delay of 75ms
+46ms ║RunTime Analysis CS > 11ms > PS > 3ms > PE > 32ms > CE
+48ms ║Runtime (38327 bytes) successfully initialized in 3ms (v0.3.113.20210203) (46ms)
+49ms ║╔Execution stage started
+56ms ║║Comparison (decimal) 1056.0 rises_to_or_above (integer) 400 = false (0ms)
+57ms ║║Condition #2 evaluated false (4ms)
+58ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+63ms ║║Comparison (decimal) 1056.0 drops_below (integer) 400 = false (1ms)
+64ms ║║Condition #15 evaluated false (4ms)
+65ms ║║Condition group #14 evaluated false (state did not change) (5ms)
+67ms ║╚Execution stage complete. (18ms)
+68ms ╚Event processed successfully (68ms)
29.3.2021, 19:57:02 +786ms
+1ms ╔Received event [Fe Bad].threeAxis = [1036,76,53] with a delay of 48ms
+51ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 31ms > CE
+53ms ║Runtime (38326 bytes) successfully initialized in 4ms (v0.3.113.20210203) (52ms)
+54ms ║╔Execution stage started
+62ms ║║Comparison (decimal) 1036.0 rises_to_or_above (integer) 400 = false (0ms)
+63ms ║║Condition #2 evaluated false (5ms)
+64ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+70ms ║║Comparison (decimal) 1036.0 drops_below (integer) 400 = false (0ms)
+71ms ║║Condition #15 evaluated false (4ms)
+72ms ║║Condition group #14 evaluated false (state did not change) (6ms)
+74ms ║╚Execution stage complete. (20ms)
+75ms ╚Event processed successfully (75ms)
29.3.2021, 19:57:01 +880ms
+1ms ╔Received event [Fe Bad].threeAxis = [1042,74,57] with a delay of 73ms
+51ms ║RunTime Analysis CS > 16ms > PS > 5ms > PE > 31ms > CE
+54ms ║Runtime (38326 bytes) successfully initialized in 5ms (v0.3.113.20210203) (51ms)
+62ms ║║Comparison (decimal) 1042.0 rises_to_or_above (integer) 400 = false (1ms)
+63ms ║║Condition #2 evaluated false (4ms)
+70ms ║║Comparison (decimal) 1042.0 drops_below (integer) 400 = false (1ms)
29.3.2021, 19:57:00 +736ms
+1ms ╔Received event [Fe Bad].threeAxis = [1055,65,67] with a delay of 44ms
+153ms ║RunTime Analysis CS > 21ms > PS > 4ms > PE > 127ms > CE
+156ms ║Runtime (38323 bytes) successfully initialized in 4ms (v0.3.113.20210203) (153ms)
+157ms ║╔Execution stage started
+164ms ║║Comparison (decimal) 1055.0 rises_to_or_above (integer) 400 = false (1ms)
+166ms ║║Cancelling condition #2’s schedules…
+167ms ║║Condition #2 evaluated false (6ms)
+168ms ║║Cancelling condition #1’s schedules…
+169ms ║║Condition group #1 evaluated false (state changed) (8ms)
+174ms ║║Comparison (decimal) 1055.0 drops_below (integer) 400 = false (1ms)
+176ms ║║Condition #15 evaluated false (5ms)
+177ms ║║Condition group #14 evaluated false (state did not change) (6ms)
+179ms ║╚Execution stage complete. (22ms)
+185ms ╚Event processed successfully (185ms)
29.3.2021, 19:56:59 +714ms
+1ms ╔Received event [Fe Bad].threeAxis = [1080,74,105] with a delay of 40ms
+48ms ║RunTime Analysis CS > 15ms > PS > 4ms > PE > 29ms > CE
+50ms ║Runtime (38324 bytes) successfully initialized in 4ms (v0.3.113.20210203) (48ms)
+51ms ║╔Execution stage started
+58ms ║║Comparison (decimal) 1080.0 rises_to_or_above (integer) 400 = true (1ms)
+60ms ║║Cancelling condition #2’s schedules…
+61ms ║║Condition #2 evaluated true (6ms)
+62ms ║║Cancelling condition #1’s schedules…
+63ms ║║Condition group #1 evaluated true (state changed) (7ms)
+65ms ║║Cancelling statement #3’s schedules…
+75ms ║║Executed virtual command sendPushNotification (7ms)
+82ms ║║Comparison (decimal) 1080.0 is_greater_than (integer) 400 = true (1ms)
+83ms ║║Condition #6 evaluated true (5ms)
+84ms ║║Condition group #5 evaluated true (state did not change) (6ms)
+86ms ║║Cancelling statement #7’s schedules…
+89ms ║║Executed virtual command wait (0ms)
+91ms ║║Requesting a wake up for Mon, Mar 29 2021 @ 7:57:09 PM CEST (in 10.0s)
+95ms ║╚Execution stage complete. (44ms)
+96ms ║Setting up scheduled job for Mon, Mar 29 2021 @ 7:57:09 PM CEST (in 9s)
+104ms ╚Event processed successfully (104ms)
29.3.2021, 19:56:58 +711ms
+1ms ╔Received event [Fe Bad].threeAxis = [3,-6,1067] with a delay of 48ms
+50ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 29ms > CE
+52ms ║Runtime (38326 bytes) successfully initialized in 4ms (v0.3.113.20210203) (50ms)
+60ms ║║Comparison (decimal) 3.0 rises_to_or_above (integer) 400 = false (1ms)
+62ms ║║Condition #2 evaluated false (4ms)
+63ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+68ms ║║Comparison (decimal) 3.0 drops_below (integer) 400 = false (1ms)
+72ms ║╚Execution stage complete. (20ms)
29.3.2021, 19:56:57 +723ms
+1ms ╔Received event [Fe Bad].threeAxis = [-1235,-237,179] with a delay of 47ms
+48ms ║RunTime Analysis CS > 14ms > PS > 4ms > PE > 30ms > CE
+50ms ║Runtime (38330 bytes) successfully initialized in 4ms (v0.3.113.20210203) (48ms)
+58ms ║║Comparison (decimal) -1235.0 rises_to_or_above (integer) 400 = false (0ms)
+59ms ║║Condition #2 evaluated false (4ms)
+60ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+65ms ║║Comparison (decimal) -1235.0 drops_below (integer) 400 = false (0ms)
+67ms ║║Condition #15 evaluated false (5ms)
+68ms ║║Condition group #14 evaluated false (state did not change) (6ms)
+69ms ║╚Execution stage complete. (18ms)
+70ms ╚Event processed successfully (70ms)
Thank you for any support!
