My piston has a restriction to only fire when location mode=DAY. The piston triggers when a motion sensor is now and stays inactive for 30 minutes. If location mode changes away from DAY during that 30 minutes of inactivity the piston still fires. It doesn’t seem to re-evaluate the restriction at the time of execution.
I would expect the restriction to be enforced and the piston should not fire.
The piston fires even though the restricted condition should block it.
Sorry, no logs in this instance.
