Quick way to determine the length of a string "array"
Would like to determine how many elements in a string “array” such as:
String = “zero, one, two , three”
This has four elements which can be accessed using:
arrayitem(n, String)
So other than looping through the string to count how many commas it contains, is there an easier way?
Thanks!
You should be able to use count(string). It will count any true values (non-zero/not empty).
Excellent, I saw that function in https://wiki.webcore.co/Functions#Integers But I assumed it was for Integers … it worked perfectly.
Thanks!
James
