READ IN a piston state (NOT SET a piston state)
Most of us are familiar with setting the state of a piston…
Is it possible to read [or assign to a var] the state of the current piston or read the state of another piston?
A textual example:
  • read state of current piston (and eg do something)
  • set state to something
  • wait
  • loop
Note: I do not want to keep track via a var or other means; I want to read the state real-time if possible.
If so, an example will be appreciated.
Thanks
J
not possible today. to suggest this feature please post here:
https://community.webcore.co/c/Meta/Feat-reqs
Can’t you set the piston state that you want to reference to a globalvariable? Those should be available to all pistons in that instance of webcore.
One could, but as I stated it is not something I want to do…
Consider this: 100 pistons = 100 global variables; the ability to real-time read a status is the way to go.
I will follow @bangali’s advise & add a feature request.
J
