This is the full (work in progress) piston. Futronix pdu is a fibaro switch, its always on & is only used to read the power used by the futronix p800 lighting controller. Kitchen lights is a virtual dimmer - its levels 1-20 are used to correspond to the scenes on the p800
I’ve coded round the issue using the final if statement of the piston, however, I’m still curious about the power level read in the main body after a scene change has been sent (prefixed with ORIG in the log)
31/01/2023, 19:36:18 +743ms
+3ms ╔Received event [Futronix PDU].power = 125.7 with a delay of 27ms, canQueue: true, calledMyself: false
+14ms ║RunTime initialize > 14 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 8 m:11 4 10)
+18ms ║Runtime (16054 bytes) initialized in 2ms (v0.3.114.20230113_HE)
+20ms ║╔Execution stage started
+24ms ║║Comparison (enum) on changes_to (string) off = false (0ms)
+25ms ║║Condition #2 evaluated false (2ms)
+25ms ║║Condition group #1 evaluated false (condition did not change) (4ms)
+28ms ║║Comparison (integer) 1 changes = false (0ms)
+28ms ║║Condition #9 evaluated false (2ms)
+30ms ║║Comparison (enum) on changes_to (string) on = false (0ms)
+32ms ║║Condition #10 evaluated false (3ms)
+33ms ║║Condition group #8 evaluated false (condition changed) (7ms)
+36ms ║║Comparison (decimal) 125.7 drops_below (decimal) 10.0 = false (1ms)
+37ms ║║Condition #46 evaluated false (3ms)
+38ms ║║Condition group #45 evaluated false (condition did not change) (3ms)
+41ms ║║Comparison (decimal) 125.7 rises_above (decimal) 10.0 = true (0ms)
+42ms ║║Condition #51 evaluated true (4ms)
+44ms ║║Condition group #50 evaluated true (condition changed) (5ms)
+46ms ║║Comparison (enum) on is (string) off = false (1ms)
+47ms ║║Condition #53 evaluated false (3ms)
+48ms ║║Condition group #52 evaluated false (condition did not change) (3ms)
+50ms ║║Comparison (decimal) 125.7 changes = true (0ms)
+52ms ║║Condition #58 evaluated true (3ms)
+53ms ║║Condition group #57 evaluated true (condition changed) (5ms)
+55ms ║║Calculating (integer)10 * (integer)1000 >> (integer)10000
+56ms ║║Calculating (datetime)1675193771005 + (integer)10000 >> (datetime)1675193781005
+60ms ║║Comparison (datetime) 1675193781005 is_greater_than (datetime) 1675193778801 = true (1ms)
+61ms ║║Condition #60 evaluated true (8ms)
+62ms ║║Condition group #59 evaluated true (condition changed) (9ms)
+68ms ║║Executed virtual command setVariable (2ms)
+72ms ║║Calculating (string)SCN + (string)0 >> (string)SCN 0
+73ms ║║Calculating (string)SCN 0 + (string) PWR >> (string)SCN 0 PWR
+75ms ║║Calculating (string)SCN 0 PWR + (string)125.7 >> (string)SCN 0 PWR 125.7
+77ms ║║SCN 0 PWR 125.7
+79ms ║║Executed virtual command log (2ms)
+82ms ║╚Execution stage complete. (63ms)
+86ms ╚Event processed successfully (83ms)
31/01/2023, 19:36:10 +940ms
+4ms ╔Received event [Home].time = 1675193770916 with a delay of 24ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 13 LockT > 0ms > r9T > 2ms > pistonT > 1ms (first state access 7 m:11 4 9)
+17ms ║Runtime (16046 bytes) initialized in 2ms (v0.3.114.20230113_HE)
+23ms ║╔Execution stage started
+60ms ║║Executed device command [Harmony Hub-Ftrnx scn01].off() (29ms)
+64ms ║║Executed virtual command [Harmony Hub-Ftrnx scn01].setVariable (1ms)
+69ms ║║Executed virtual command [Harmony Hub-Ftrnx scn01].setVariable (1ms)
+160ms ║║Executed device command [Futronix PDU].refresh() (87ms)
+166ms ║║Executed virtual command [Futronix PDU].setVariable (3ms)
+171ms ║║Calculating (string)Orig SCN + (string)0 >> (string)Orig SCN 0
+172ms ║║Calculating (string)Orig SCN 0 + (string) PWR >> (string)Orig SCN 0 PWR
+174ms ║║Calculating (string)Orig SCN 0 PWR + (string)3.2 >> (string)Orig SCN 0 PWR 3.2
+177ms ║║Orig SCN 0 PWR 3.2
+179ms ║║Executed virtual command [Futronix PDU].log (2ms)
+182ms ║║Comparison (integer) 1 is_equal_to (integer) 100 = false (1ms)
+183ms ║║Condition #34 evaluated false (3ms)
+184ms ║║Condition group #33 evaluated false (condition did not change) (4ms)
+186ms ║║Comparison (boolean) true is_not (boolean) true = false (1ms)
+187ms ║║Condition #42 evaluated false (3ms)
+188ms ║║Condition group #41 evaluated false (condition did not change) (3ms)
+191ms ║║Comparison (decimal) 3.2 drops_below (decimal) 10.0 = false (0ms)
+192ms ║║Condition #46 evaluated false (3ms)
+192ms ║║Condition group #45 evaluated false (condition did not change) (4ms)
+195ms ║║Comparison (decimal) 3.2 rises_above (decimal) 10.0 = false (1ms)
+196ms ║║Condition #51 evaluated false (3ms)
+197ms ║║Condition group #50 evaluated false (condition did not change) (3ms)
+199ms ║║Comparison (decimal) 3.2 changes = false (0ms)
+201ms ║║Condition #58 evaluated false (3ms)
+202ms ║║Condition group #57 evaluated false (condition changed) (5ms)
+204ms ║╚Execution stage complete. (182ms)
+207ms ╚Event processed successfully (204ms)
31/01/2023, 19:36:08 +651ms
+2ms ╔Received event [Kitchen Lights].switch = on with a delay of 43ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 6 m:9 3 9)
+18ms ║Runtime (15979 bytes) initialized in 2ms (v0.3.114.20230113_HE)
+24ms ║║Comparison (enum) on changes_to (string) off = false (1ms)
+25ms ║║Condition #2 evaluated false (3ms)
+26ms ║║Condition group #1 evaluated false (condition did not change) (3ms)
+29ms ║║Comparison (integer) 1 changes = false (0ms)
+29ms ║║Condition #9 evaluated false (2ms)
+32ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+33ms ║║Condition #10 evaluated true (3ms)
+35ms ║║Condition group #8 evaluated true (condition changed) (8ms)
+40ms ║║Executed virtual command setVariable (2ms)
+43ms ║║Calculating (integer)1 - (integer)1 >> (integer)0
+46ms ║║Executed virtual command setVariable (1ms)
+48ms ║║Calculating (integer)2 * (integer)1000 >> (integer)2000
+50ms ║║Calculating (datetime)1675191409206 + (integer)2000 >> (datetime)1675191411206
+53ms ║║Comparison (datetime) 1675191411206 is_less_than (datetime) 1675193768702 = true (2ms)
