Need to set up a trigger that fires when relative humidity increases by a certain percentage (or more ideally, a certain number of percentage points) within a given amount of time). I currently have it set to fire when humidity increases beyond a certain value. In other words, I want: (“fire when humidity increases by 10% in 5 minutes or less” – rather than “fire when humidity exceeds 75%”
I have my bathroom lighting set to change when a shower is detected. When humidity changes enough (shower detected) the lights change. Currently, my trigger is when humidity rises to 75% or greater.
The piston works fine except for this problem: On cold days when the air is extra dry, the shower doesn’t cause the humidity to rise above 75% or for long enough, so the lights don’t change. On warmer, more humid days, it’s not an issue. I want this trigger to work regardless of what the baseline humidity is that day. I want the code to basically evaluate: “Has humidity risen X percentage points in the last X minutes.” I will also need the false statement of this trigger (if that’s the right term) because I have other conditions that currently say, “if humidity is below 75%, then do this instead.” So if I switch up this trigger, I will also need to know how to code the false version of that as well. Hope that makes sense.
(UPLOAD YOUR IMAGE HERE)
Not needed. Piston works except for trigger.
