Here is ST logs:
2017-08-24 6:41 PM EDT - moments ago button held
Here is webCore:
8/24/2017, 6:41:52 PM +121ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 1172ms
+12790ms ║RunTime Analysis CS > 35ms > PS > 12463ms > PE > 292ms > CE
+12798ms ║Piston waited at a semaphore for 12319ms
+12802ms ║Runtime (57624 bytes) successfully initialized in 12463ms (v0.2.0e5.20170812) (12800ms)
+12804ms ║╔Execution stage started
+12826ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+12829ms ║║Condition #47 evaluated false (13ms)
+12830ms ║║Condition group #46 evaluated false (state did not change) (15ms)
+12850ms ║║Comparison (enum) held gets (string) held = true (7ms)
+12852ms ║║Condition #65 evaluated true (16ms)
+12854ms ║║Condition group #64 evaluated true (state did not change) (18ms)
+12859ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+12864ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+12868ms ║║Cancelling statement #122’s schedules…
+12885ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (6ms)
+12886ms ║║Executed [Corner Cabinet Light].setLevel (10ms)
+12896ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (7ms)
+12898ms ║║Executed [Kitchen Table Light].setLevel (8ms)
+12907ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (6ms)
+12908ms ║║Executed [Refrigerator Light].setLevel (8ms)
+12919ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (8ms)
+12921ms ║║Executed [Sink Light].setLevel (10ms)
+12931ms ║║Skipped execution of physical command [Stove Light].setLevel([1]) because it would make no change to the device. (6ms)
+12932ms ║║Executed [Stove Light].setLevel (8ms)
+12952ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (5ms)
+12955ms ║║Condition #92 evaluated false (14ms)
+12956ms ║║Condition group #91 evaluated false (state did not change) (16ms)
+12961ms ║║Cancelling statement #132’s schedules…
+12980ms ║║Calculating (string) button + (string) # >> (string) button #
+12985ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+12990ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+12994ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+13003ms ║║Calculating (string) b, + (string) red >> (string) b, red
+13008ms ║║Calculating (string) >> (string)
+13014ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+13018ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+13022ms ║║Executed virtual command setState (1ms)
+13025ms ║╚Execution stage complete. (222ms)
+13033ms ╚Event processed successfully (13033ms)
8/24/2017, 6:41:52 PM +125ms
+1ms ╔Received event [Remote Buttons].button = held with a delay of 1266ms
+6882ms ║RunTime Analysis CS > 35ms > PS > 6467ms > PE > 380ms > CE
+6890ms ║Piston waited at a semaphore for 6393ms
+6895ms ║Runtime (57618 bytes) successfully initialized in 6467ms (v0.2.0e5.20170812) (6892ms)
+6897ms ║╔Execution stage started
+6923ms ║║Comparison (enum) held gets (string) pushed = false (2ms)
+6926ms ║║Condition #47 evaluated false (12ms)
+6927ms ║║Condition group #46 evaluated false (state did not change) (15ms)
+6945ms ║║Comparison (enum) held gets (string) held = true (3ms)
+6948ms ║║Condition #65 evaluated true (14ms)
+6949ms ║║Condition group #64 evaluated true (state did not change) (16ms)
+6955ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+6963ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+6968ms ║║Cancelling statement #122’s schedules…
+6989ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (8ms)
+6990ms ║║Executed [Corner Cabinet Light].setLevel (10ms)
+7007ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (8ms)
+7008ms ║║Executed [Kitchen Table Light].setLevel (12ms)
+7019ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (6ms)
+7020ms ║║Executed [Refrigerator Light].setLevel (8ms)
+7032ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (7ms)
+7033ms ║║Executed [Sink Light].setLevel (9ms)
+7044ms ║║Skipped execution of physical command [Stove Light].setLevel([1]) because it would make no change to the device. (8ms)
+7046ms ║║Executed [Stove Light].setLevel (9ms)
+7070ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (5ms)
+7073ms ║║Condition #92 evaluated false (14ms)
+7075ms ║║Condition group #91 evaluated false (state did not change) (18ms)
+7083ms ║║Cancelling statement #132’s schedules…
+7119ms ║║Calculating (string) button + (string) # >> (string) button #
+7126ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+7132ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+7139ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+7150ms ║║Calculating (string) b, + (string) red >> (string) b, red
+7159ms ║║Calculating (string) >> (string)
+7168ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+7175ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+7183ms ║║Executed virtual command setState (2ms)
+7188ms ║╚Execution stage complete. (292ms)
+7196ms ╚Event processed successfully (7196ms)
8/24/2017, 6:41:51 PM +696ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 1196ms
+6336ms ║RunTime Analysis CS > 99ms > PS > 5691ms > PE > 546ms > CE
+6344ms ║Piston waited at a semaphore for 5614ms
+6347ms ║Runtime (57618 bytes) successfully initialized in 5691ms (v0.2.0e5.20170812) (6344ms)
+6348ms ║╔Execution stage started
+6368ms ║║Comparison (enum) held gets (string) pushed = false (2ms)
+6371ms ║║Condition #47 evaluated false (11ms)
+6372ms ║║Condition group #46 evaluated false (state did not change) (14ms)
+6390ms ║║Comparison (enum) held gets (string) held = true (5ms)
+6393ms ║║Condition #65 evaluated true (14ms)
+6394ms ║║Condition group #64 evaluated true (state did not change) (17ms)
+6399ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+6405ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+6409ms ║║Cancelling statement #122’s schedules…
+6426ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (6ms)
+6427ms ║║Executed [Corner Cabinet Light].setLevel (8ms)
+6437ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (7ms)
+6438ms ║║Executed [Kitchen Table Light].setLevel (9ms)
+6448ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (6ms)
+6450ms ║║Executed [Refrigerator Light].setLevel (8ms)
+6461ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (7ms)
+6462ms ║║Executed [Sink Light].setLevel (9ms)
+6472ms ║║Skipped execution of physical command [Stove Light].setLevel([1]) because it would make no change to the device. (7ms)
+6473ms ║║Executed [Stove Light].setLevel (9ms)
+6487ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (2ms)
+6489ms ║║Condition #92 evaluated false (8ms)
+6490ms ║║Condition group #91 evaluated false (state did not change) (11ms)
+6495ms ║║Cancelling statement #132’s schedules…
+6514ms ║║Calculating (string) button + (string) # >> (string) button #
+6519ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+6524ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+6528ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+6537ms ║║Calculating (string) b, + (string) red >> (string) b, red
+6542ms ║║Calculating (string) >> (string)
+6547ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+6551ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+6555ms ║║Executed virtual command setState (1ms)
+6558ms ║╚Execution stage complete. (210ms)
+6567ms ╚Event processed successfully (6568ms)
8/24/2017, 6:41:55 PM +213ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 1141ms
+1547ms ║RunTime Analysis CS > 39ms > PS > 1197ms > PE > 311ms > CE
+1665ms ║Piston waited at a semaphore for 1135ms
+1668ms ║Runtime (57618 bytes) successfully initialized in 1197ms (v0.2.0e5.20170812) (1666ms)
+1670ms ║╔Execution stage started
+1688ms ║║Comparison (enum) held gets (string) pushed = false (2ms)
+1690ms ║║Condition #47 evaluated false (10ms)
+1692ms ║║Condition group #46 evaluated false (state did not change) (12ms)
+1706ms ║║Comparison (enum) held gets (string) held = true (2ms)
+1708ms ║║Condition #65 evaluated true (11ms)
+1709ms ║║Condition group #64 evaluated true (state did not change) (13ms)
+1714ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+1719ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+1723ms ║║Cancelling statement #122’s schedules…
+1738ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (6ms)
+1739ms ║║Executed [Corner Cabinet Light].setLevel (7ms)
+1748ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (6ms)
+1749ms ║║Executed [Kitchen Table Light].setLevel (7ms)
+1756ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (4ms)
+1757ms ║║Executed [Refrigerator Light].setLevel (6ms)
+1767ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (6ms)
+1767ms ║║Executed [Sink Light].setLevel (8ms)
+1776ms ║║Skipped execution of physical command [Stove Light].setLevel([1]) because it would make no change to the device. (6ms)
+1777ms ║║Executed [Stove Light].setLevel (7ms)
+1791ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (3ms)
+1793ms ║║Condition #92 evaluated false (9ms)
+1795ms ║║Condition group #91 evaluated false (state did not change) (11ms)
+1800ms ║║Cancelling statement #132’s schedules…
+1820ms ║║Calculating (string) button + (string) # >> (string) button #
+1825ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+1831ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+1835ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+1847ms ║║Calculating (string) b, + (string) red >> (string) b, red
+1854ms ║║Calculating (string) >> (string)
+1859ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+1864ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+1868ms ║║Executed virtual command setState (1ms)
+1872ms ║╚Execution stage complete. (202ms)
+1878ms ╚Event processed successfully (1878ms)
8/24/2017, 6:41:55 PM +735ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 1236ms
+943ms ║RunTime Analysis CS > 31ms > PS > 640ms > PE > 271ms > CE
+951ms ║Piston waited at a semaphore for 580ms
+954ms ║Runtime (57612 bytes) successfully initialized in 640ms (v0.2.0e5.20170812) (952ms)
+956ms ║╔Execution stage started
+973ms ║║Comparison (enum) held gets (string) pushed = false (2ms)
+975ms ║║Condition #47 evaluated false (9ms)
+977ms ║║Condition group #46 evaluated false (state did not change) (11ms)
+990ms ║║Comparison (enum) held gets (string) held = true (3ms)
+992ms ║║Condition #65 evaluated true (10ms)
+993ms ║║Condition group #64 evaluated true (state did not change) (12ms)
+998ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+1003ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+1007ms ║║Cancelling statement #122’s schedules…
+1021ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (5ms)
+1023ms ║║Executed [Corner Cabinet Light].setLevel (7ms)
+1031ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (6ms)
+1032ms ║║Executed [Kitchen Table Light].setLevel (7ms)
+1041ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (5ms)
+1042ms ║║Executed [Refrigerator Light].setLevel (7ms)
+1052ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (6ms)
+1052ms ║║Executed [Sink Light].setLevel (8ms)
+1061ms ║║Skipped execution of physical command [Stove Light].setLevel([1]) because it would make no change to the device. (6ms)
+1062ms ║║Executed [Stove Light].setLevel (8ms)
+1076ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (3ms)
+1078ms ║║Condition #92 evaluated false (9ms)
+1079ms ║║Condition group #91 evaluated false (state did not change) (11ms)
+1084ms ║║Cancelling statement #132’s schedules…
+1103ms ║║Calculating (string) button + (string) # >> (string) button #
+1108ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+1113ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+1117ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+1126ms ║║Calculating (string) b, + (string) red >> (string) b, red
+1131ms ║║Calculating (string) >> (string)
+1136ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+1140ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+1145ms ║║Executed virtual command setState (1ms)
+1148ms ║╚Execution stage complete. (193ms)
+1155ms ╚Event processed successfully (1155ms)
8/24/2017, 6:41:53 PM +431ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 1672ms
+1099ms ║RunTime Analysis CS > 184ms > PS > 430ms > PE > 486ms > CE
+1110ms ║Piston waited at a semaphore for 359ms
+1116ms ║Runtime (57615 bytes) successfully initialized in 430ms (v0.2.0e5.20170812) (1113ms)
+1117ms ║╔Execution stage started
+1141ms ║║Comparison (enum) held gets (string) pushed = false (2ms)
+1144ms ║║Condition #47 evaluated false (12ms)
+1146ms ║║Condition group #46 evaluated false (state did not change) (16ms)
+1167ms ║║Comparison (enum) held gets (string) held = true (7ms)
+1169ms ║║Condition #65 evaluated true (16ms)
+1171ms ║║Condition group #64 evaluated true (state did not change) (18ms)
+1176ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+1182ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+1186ms ║║Cancelling statement #122’s schedules…
+1203ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (6ms)
+1205ms ║║Executed [Corner Cabinet Light].setLevel (9ms)
+1217ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (7ms)
+1219ms ║║Executed [Kitchen Table Light].setLevel (10ms)
+1230ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (7ms)
+1231ms ║║Executed [Refrigerator Light].setLevel (9ms)
+1241ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (6ms)
+1243ms ║║Executed [Sink Light].setLevel (8ms)
+1376ms ║║Executed physical command [Stove Light].setLevel([1]) (128ms)
+1377ms ║║Executed [Stove Light].setLevel (130ms)
+1392ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (3ms)
+1394ms ║║Condition #92 evaluated false (10ms)
+1396ms ║║Condition group #91 evaluated false (state did not change) (12ms)
+1401ms ║║Cancelling statement #132’s schedules…
+1422ms ║║Calculating (string) button + (string) # >> (string) button #
+1428ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+1433ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+1437ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+1447ms ║║Calculating (string) b, + (string) red >> (string) b, red
+1453ms ║║Calculating (string) >> (string)
+1459ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+1463ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+1468ms ║║Executed virtual command setState (1ms)
+1472ms ║╚Execution stage complete. (355ms)
+1478ms ╚Event processed successfully (1478ms)
8/24/2017, 6:41:52 PM +82ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 729ms
+2300ms ║RunTime Analysis CS > 58ms > PS > 1862ms > PE > 380ms > CE
+2307ms ║Piston waited at a semaphore for 1785ms
+2310ms ║Runtime (57617 bytes) successfully initialized in 1862ms (v0.2.0e5.20170812) (2307ms)
+2311ms ║╔Execution stage started
+2330ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+2332ms ║║Condition #47 evaluated false (10ms)
+2333ms ║║Condition group #46 evaluated false (state did not change) (12ms)
+2347ms ║║Comparison (enum) held gets (string) held = true (3ms)
+2349ms ║║Condition #65 evaluated true (11ms)
+2351ms ║║Condition group #64 evaluated true (state did not change) (12ms)
+2355ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+2361ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+2365ms ║║Cancelling statement #122’s schedules…
+2380ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (6ms)
+2381ms ║║Executed [Corner Cabinet Light].setLevel (8ms)
+2393ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (8ms)
+2394ms ║║Executed [Kitchen Table Light].setLevel (10ms)
+2402ms ║║Skipped execution of physical command [Refrigerator Light].setLevel([1]) because it would make no change to the device. (5ms)
+2403ms ║║Executed [Refrigerator Light].setLevel (7ms)
+2413ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (7ms)
+2414ms ║║Executed [Sink Light].setLevel (9ms)
+2475ms ║║Executed physical command [Stove Light].setLevel([1]) (57ms)
+2476ms ║║Executed [Stove Light].setLevel (59ms)
+2498ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (5ms)
+2502ms ║║Condition #92 evaluated false (15ms)
+2505ms ║║Condition group #91 evaluated false (state did not change) (19ms)
+2513ms ║║Cancelling statement #132’s schedules…
+2535ms ║║Calculating (string) button + (string) # >> (string) button #
+2540ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+2546ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+2551ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+2563ms ║║Calculating (string) b, + (string) red >> (string) b, red
+2571ms ║║Calculating (string) >> (string)
+2579ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+2587ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+2592ms ║║Executed virtual command setState (1ms)
+2598ms ║╚Execution stage complete. (286ms)
+2608ms ╚Event processed successfully (2608ms)
8/24/2017, 6:41:52 PM +320ms
+2ms ╔Received event [Remote Buttons].button = held with a delay of 324ms
+908ms ║RunTime Analysis CS > 51ms > PS > 417ms > PE > 440ms > CE
+917ms ║Piston waited at a semaphore for 333ms
+922ms ║Runtime (57613 bytes) successfully initialized in 417ms (v0.2.0e5.20170812) (919ms)
+925ms ║╔Execution stage started
+945ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+948ms ║║Cancelling condition #47’s schedules…
+949ms ║║Condition #47 evaluated false (12ms)
+951ms ║║Cancelling condition #46’s schedules…
+952ms ║║Condition group #46 evaluated false (state changed) (16ms)
+969ms ║║Comparison (enum) held gets (string) held = true (4ms)
+973ms ║║Cancelling condition #65’s schedules…
+974ms ║║Condition #65 evaluated true (15ms)
+976ms ║║Cancelling condition #64’s schedules…
+977ms ║║Condition group #64 evaluated true (state changed) (19ms)
+982ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+987ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+991ms ║║Cancelling statement #122’s schedules…
+1009ms ║║Skipped execution of physical command [Corner Cabinet Light].setLevel([1]) because it would make no change to the device. (7ms)
+1010ms ║║Executed [Corner Cabinet Light].setLevel (9ms)
+1021ms ║║Skipped execution of physical command [Kitchen Table Light].setLevel([1]) because it would make no change to the device. (7ms)
+1022ms ║║Executed [Kitchen Table Light].setLevel (8ms)
+1071ms ║║Executed physical command [Refrigerator Light].setLevel([1]) (44ms)
+1072ms ║║Executed [Refrigerator Light].setLevel (46ms)
+1084ms ║║Skipped execution of physical command [Sink Light].setLevel([1]) because it would make no change to the device. (8ms)
+1085ms ║║Executed [Sink Light].setLevel (10ms)
+1136ms ║║Executed physical command [Stove Light].setLevel([1]) (47ms)
+1137ms ║║Executed [Stove Light].setLevel (49ms)
+1153ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (4ms)
+1156ms ║║Condition #92 evaluated false (11ms)
+1157ms ║║Condition group #91 evaluated false (state did not change) (13ms)
+1166ms ║║Cancelling statement #132’s schedules…
+1191ms ║║Calculating (string) button + (string) # >> (string) button #
+1196ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+1202ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+1207ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+1217ms ║║Calculating (string) b, + (string) red >> (string) b, red
+1223ms ║║Calculating (string) >> (string)
+1228ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+1233ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+1237ms ║║Executed virtual command setState (1ms)
+1242ms ║╚Execution stage complete. (318ms)
+1252ms ╚Event processed successfully (1251ms)
8/24/2017, 6:41:51 PM +215ms
+1ms ╔Received event [Remote Buttons].button = held with a delay of 901ms
+522ms ║RunTime Analysis CS > 36ms > PS > 85ms > PE > 402ms > CE
+532ms ║Runtime (57549 bytes) successfully initialized in 85ms (v0.2.0e5.20170812) (530ms)
+534ms ║╔Execution stage started
+556ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+558ms ║║Cancelling condition #47’s schedules…
+559ms ║║Condition #47 evaluated false (14ms)
+561ms ║║Cancelling condition #46’s schedules…
+562ms ║║Condition group #46 evaluated false (state changed) (17ms)
+575ms ║║Comparison (enum) held gets (string) held = true (3ms)
+577ms ║║Cancelling condition #65’s schedules…
+578ms ║║Condition #65 evaluated true (11ms)
+580ms ║║Cancelling condition #64’s schedules…
+581ms ║║Condition group #64 evaluated true (state changed) (15ms)
+585ms ║║Evaluating switch with values [[i:66:null:0, v:[t:integer, v:1, vt:string]]]
+590ms ║║Comparison (integer) 1 is (integer) 1 = true (3ms)
+594ms ║║Cancelling statement #122’s schedules…
+640ms ║║Executed physical command [Corner Cabinet Light].setLevel([1]) (38ms)
+641ms ║║Executed [Corner Cabinet Light].setLevel (39ms)
+687ms ║║Executed physical command [Kitchen Table Light].setLevel([1]) (42ms)
+688ms ║║Executed [Kitchen Table Light].setLevel (45ms)
+918ms ║║Executed physical command [Refrigerator Light].setLevel([1]) (227ms)
+920ms ║║Executed [Refrigerator Light].setLevel (229ms)
+1013ms ║║Executed physical command [Sink Light].setLevel([1]) (88ms)
+1014ms ║║Executed [Sink Light].setLevel (90ms)
+1152ms ║║Executed physical command [Stove Light].setLevel([1]) (134ms)
+1153ms ║║Executed [Stove Light].setLevel (137ms)
+1173ms ║║Comparison (integer) 1 is_different_than (integer) 1 = false (3ms)
+1176ms ║║Condition #92 evaluated false (11ms)
+1178ms ║║Condition group #91 evaluated false (state did not change) (14ms)
+1185ms ║║Cancelling statement #132’s schedules…
+1205ms ║║Calculating (string) button + (string) # >> (string) button #
+1210ms ║║Calculating (string) button # + (string) 1 >> (string) button #1
+1214ms ║║Calculating (string) button #1 + (string) >> (string) button #1
+1219ms ║║Calculating (string) button #1 + (string) held >> (string) button #1 held
+1228ms ║║Calculating (string) b, + (string) red >> (string) b, red
+1233ms ║║Calculating (string) >> (string)
+1237ms ║║Calculating (string) + (string) BUTTON #1 HELD >> (string) BUTTON #1 HELD
+1242ms ║║Calculating (string) BUTTON #1 HELD + (string) >> (string) BUTTON #1 HELD
+1246ms ║║Executed virtual command setState (1ms)
+1249ms ║╚Execution stage complete. (716ms)
+1256ms ╚Event processed successfully (1256ms)
Sorry…can’t figure out how to do the scrolling logs thing.
