I would need a piston that has this function
Location Mode changes to … with SecurityCheckGlobal turn off…
If from now a switch change to on remove the device from SecurityCheckGlobal
Wait 5 Min
Check the devices in securityCheckGlobal and …
Point 1, 3 and 4 i have solved. But I need help with point 2.
the problem right now is that after the routine good night has been executed, a light is turned on and it goes through the for each check directly off again.
