This is a heatlamp control I created to control the heat within a crabitat for hermit crabs.
It could be used for reptiles such as lizards or snakes etc…
Turns on day heat lamp at sunrise, turns off at sunset and turns the night heat lamp on at sunset.
If temp rises above 82 turns off day heat lamp. If temp rises above 85 sends sms message.
If temps stays equal to or above 85 by checking every 30 minutes after it rises to 85 it will continue to send an sms message with current temp.
