Request suggestion for improvement Garage controller
c808788
this current setting working ok but there is a delay upto 2 mins
what i would like to do is garage close immediately when hallway door open any suggestion to improve on this piston ???
WCmore
Your only trigger (lightning bolt in the left margin), is on presence changes, so that is when the 2 minutes begins…
This logic should be in a separate block, or piston.
IF hallway door changes to open <-- Trigger
Close Garage Door
END IF
c808788
Hi WCmore
thanks for the quick response.
I have tried all that suggestion from you however i forgot to mention . Condition of the hallway trigger by open then close Or hallway door already open then the trigger is by closed the hallway door
WCmore
Both of those are achieved with a slight modification of my last post. Something like:
IF hallway door changes to close <-- Trigger
Close Garage Door
END IF
It will begin closing the Garage the moment the hallway door closes.
(regardless of how long the door was open for)
