I have a piston that triggers daily at a time with an offset where both the time and offset are defined in variables. I have a separate piston that may modify the offset. However, when the offset is modified, the timer does not change so the event happens at the original time without the offset. Then when it sets up for the event to trigger the next day it sets it up with the offset.
The piston is set to trigger at 9pm with 0 minute offset. I modify the offset to -15, then the piston is set to trigger at 8:45pm today.
The piston is set to trigger at 9pm with 0 minute offset. I modify the offset to -15, then the piston is still set to trigger at 9pm. After 9pm the piston is set to trigger the next day at 8:45pm.
7/19/2021, 8:44:59 PM +61ms
+0ms ╔Received event [Home].time = 1626741900000 with a delay of -940ms
+45ms ║Runtime (37398 bytes) successfully initialized in 7ms (v0.3.110.20191009) (44ms)
+46ms ║╔Execution stage started
+150ms ║║Executed virtual command iftttMaker (86ms)
+153ms ║║Executed virtual command setVariable (1ms)
+155ms ║╚Execution stage complete. (109ms)
+157ms ║Setting up scheduled job for Mon, Jul 19 2021 @ 9:00:00 PM EDT (in 900.783s)
+164ms ╚Event processed successfully (165ms)
7/18/2021, 8:59:59 PM +82ms
+0ms ╔Received event [Home].time = 1626656400000 with a delay of -919ms
+51ms ║Runtime (37400 bytes) successfully initialized in 9ms (v0.3.110.20191009) (49ms)
+52ms ║╔Execution stage started
+568ms ║║Executed virtual command iftttMaker (98ms)
+576ms ║║Executed virtual command setVariable (3ms)
+580ms ║╚Execution stage complete. (527ms)
+582ms ║Setting up scheduled job for Mon, Jul 19 2021 @ 8:45:00 PM EDT (in 85500.337s)
+598ms ╚Event processed successfully (597ms)
