Stair 1 & 2 are not returning to their orginal state
Stairs 1 & 2 to return to original state after 10 seconds of inactive from both motion sensors
The stair lights remain on
12/2/2020, 12:38:58 PM +57ms
+1ms ╔Received event [Home].time = 1606934339841 with a delay of -1784ms
+233ms ║RunTime Analysis CS > 16ms > PS > 191ms > PE > 25ms > CE
+235ms ║Runtime (45861 bytes) successfully initialized in 191ms (v0.3.110.20191009) (234ms)
+236ms ║╔Execution stage started
+259ms ║║Cancelling condition #30's schedules...
+260ms ║║Condition #30 evaluated true (1ms)
+261ms ║║Cancelling condition #29's schedules...
+261ms ║║Condition group #29 evaluated true (state changed) (3ms)
+263ms ║║Cancelling statement #31's schedules...
+279ms ║║Executed virtual command [Stairs 1].loadStateLocally (1ms)
+281ms ║║Executed virtual command [Stairs 2].loadStateLocally (1ms)
+284ms ║╚Execution stage complete. (47ms)
+285ms ╚Event processed successfully (285ms)
12/2/2020, 12:38:49 PM +682ms
+1ms ╔Received event [Hue Motion Sensor Upstairs].motion = inactive with a delay of 72ms
+102ms ║RunTime Analysis CS > 22ms > PS > 58ms > PE > 21ms > CE
+104ms ║Runtime (45869 bytes) successfully initialized in 58ms (v0.3.110.20191009) (102ms)
+117ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+118ms ║║Cancelling condition #2's schedules...
+119ms ║║Condition #2 evaluated false (10ms)
+120ms ║║Cancelling condition #1's schedules...
+121ms ║║Condition group #1 evaluated false (state changed) (12ms)
+130ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+131ms ║║Cancelling condition #12's schedules...
+132ms ║║Condition #12 evaluated false (9ms)
+133ms ║║Condition group #11 evaluated false (state did not change) (10ms)
+142ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+143ms ║║Cancelling condition #22's schedules...
+144ms ║║Condition #22 evaluated false (9ms)
+145ms ║║Condition group #21 evaluated false (state did not change) (10ms)
+155ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+157ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+159ms ║║Adding a timed trigger schedule for condition 30
+161ms ║║Condition #30 evaluated false (14ms)
+162ms ║║Condition group #29 evaluated false (state did not change) (15ms)
+164ms ║╚Execution stage complete. (59ms)
+165ms ║Setting up scheduled job for Wed, Dec 2 2020 @ 12:38:59 PM CST (in 9.994s)
+174ms ╚Event processed successfully (174ms)
12/2/2020, 12:38:39 PM +901ms
+2ms ╔Received event [Hue Motion Sensor Upstairs].motion = active with a delay of 72ms
+101ms ║RunTime Analysis CS > 18ms > PS > 60ms > PE > 23ms > CE
+104ms ║Runtime (45866 bytes) successfully initialized in 60ms (v0.3.110.20191009) (102ms)
+119ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+121ms ║║Cancelling condition #2's schedules...
+122ms ║║Condition #2 evaluated true (11ms)
+153ms ║║Comparison (time) 45520024 is_between (time) 1606912920000 .. (time) 1606948380000 = true (9ms)
+155ms ║║Time restriction check passed
+156ms ║║Condition #3 evaluated true (34ms)
+161ms ║║Comparison (string) :6621ba72b7bb391bf4347524875c94c3: is_not (string) :1536fd0f83572e449ccc2436cfbd6363: = true (2ms)
+163ms ║║Condition #4 evaluated true (5ms)
+172ms ║║Comparison (enum) off is (string) off = true (1ms)
+174ms ║║Condition #5 evaluated true (10ms)
+175ms ║║Cancelling condition #1's schedules...
+176ms ║║Condition group #1 evaluated true (state changed) (66ms)
+178ms ║║Cancelling statement #6's schedules...
+196ms ║║Executed virtual command [Stairs 1].saveStateLocally (13ms)
+212ms ║║Executed virtual command [Stairs 2].saveStateLocally (14ms)
+221ms ║║Executed physical command [Stairs 1].setColorTemperature([2700]) (6ms)
+222ms ║║Executed [Stairs 1].setColorTemperature (8ms)
+229ms ║║Executed physical command [Stairs 2].setColorTemperature([2700]) (6ms)
+230ms ║║Executed [Stairs 2].setColorTemperature (7ms)
+241ms ║║Executed physical command [Stairs 1].setLevel([100]) (8ms)
+242ms ║║Executed [Stairs 1].setLevel (9ms)
+256ms ║║Executed physical command [Stairs 2].setLevel([100]) (12ms)
+257ms ║║Executed [Stairs 2].setLevel (14ms)
+264ms ║║Skipped execution of physical command [Stairs 1].on([]) because it would make no change to the device. (4ms)
+264ms ║║Executed [Stairs 1].on (6ms)
+274ms ║║Executed physical command [Stairs 2].on() (8ms)
+275ms ║║Executed [Stairs 2].on (10ms)
+285ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+287ms ║║Cancelling condition #12's schedules...
+288ms ║║Condition #12 evaluated true (10ms)
+300ms ║║Comparison (time) 45520190 is_between (time) 1606948380000 .. (time) 1606912920000 = false (9ms)
+302ms ║║Condition #13 evaluated false (14ms)
+303ms ║║Condition group #11 evaluated false (state did not change) (25ms)
+313ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+315ms ║║Cancelling condition #22's schedules...
+316ms ║║Condition #22 evaluated true (11ms)
+320ms ║║Comparison (string) :6621ba72b7bb391bf4347524875c94c3: is (string) :1536fd0f83572e449ccc2436cfbd6363: = false (1ms)
+321ms ║║Condition #23 evaluated false (4ms)
+322ms ║║Condition group #21 evaluated false (state did not change) (17ms)
+333ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+335ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+337ms ║║Cancelling any timed trigger schedules for condition 30
+338ms ║║Cancelling statement #30's schedules...
+339ms ║║Cancelling condition #30's schedules...
+340ms ║║Condition #30 evaluated false (15ms)
+341ms ║║Cancelling condition #29's schedules...
+342ms ║║Condition group #29 evaluated false (state changed) (18ms)
+344ms ║╚Execution stage complete. (239ms)
+345ms ╚Event processed successfully (345ms)
