Sorry I really didn’t see a category this fit in. I DID IT!!! I messed up and deleted a global variable thinking I’d clicked on the correct one to delete. I didn’t pay any attention to which one I deleted. Is there any way to restore one that was deleted? Or am I going to have to go through every piston line by line and figure out which one it was?
GRRRRR
Bob
Restore Deleted Global Variable?
chop249
WCmore
No particular piston is required to make a global variable.
You can simply recreate it the way you did originally.
- Click on any piston
- Click on Edit
- Scroll down the right column a bit
- Click on “+ add a new global variable”
Once you have saved the global, you can cancel the piston edit
