Color looping will not perform.
Loop through colors on Lightify RGBW lights until motion is active, then change the color temp to a specific value, then return to color looping when motion is not active.
When motion triggers the piston, the proper commands are sent and the lights respond correctly. However, when the motion is not active, the loopOn command is sent correctly and the device logs the “loopOn” event, but the light changes to Orange color and won’t loop. After the device is turned off, then back on and the Loop command is turned off then on, the color looping correctly works.
5) Attach any logs
Won’t let me…too many links for a new user.
Thanks in advance!!
