I’d like to specify when, either a specific time frame, or only during certain modes, that this piston should run. Not sure where to put it though, help!
Run piston during certain modes
c1arkbar
Add a new condition and change physical device to virtual device. You can then select based on mode or timeframe.
Alternatively you can click the funnel button along the top and add a restriction and using the same thing as above select time or mode.
dtm2525
Does it matter where I add that new condition? I’m unsure if it needs to be the first thing on the page, or if it’s location has any effect?
c1arkbar
If you don’t want any of the conditions executing outside of the period then you will need to add the condition to each statement. Otherwise you could add a restriction to the whole piston
