| +319ms |
║RunTime Analysis CS > 35ms > PS > 105ms > PE > 176ms > CE |
| +325ms |
║Runtime (131680 bytes) successfully initialized in 105ms (v0.3.105.20180628) (320ms) |
| +329ms |
║╔Execution stage started |
| +367ms |
║║Cancelling statement #3’s schedules… |
| +404ms |
║║Executed virtual command [Corner Go].setVariable (9ms) |
| +416ms |
║║Executed virtual command [Corner Go].setVariable (4ms) |
| +425ms |
║║Executed virtual command [Corner Go].setVariable (3ms) |
| +435ms |
| +448ms |
║║Comparison (decimal) 0.0 is_equal_to (integer) 0 = true (4ms) |
| +452ms |
║║Cancelling condition #19’s schedules… |
| +453ms |
║║Condition #19 evaluated true (15ms) |
| +454ms |
║║Cancelling condition #14’s schedules… |
| +455ms |
║║Condition group #14 evaluated true (state changed) (17ms) |
| +458ms |
║║Cancelling statement #17’s schedules… |
| +475ms |
║║Calculating (string) Corner Go + (string) , >> (string) Corner Go, |
| +479ms |
║║Calculating (string) Corner Go, + (string) on >> (string) Corner Go,on |
| +482ms |
║║Calculating (string) Corner Go,on + (string) , >> (string) Corner Go,on, |
| +485ms |
║║Calculating (string) Corner Go,on, + (string) 68 >> (string) Corner Go,on,68 |
| +489ms |
║║Calculating (string) Corner Go,on,68 + (string) , >> (string) Corner Go,on,68, |
| +492ms |
║║Calculating (string) Corner Go,on,68, + (string) 259 >> (string) Corner Go,on,68,259 |
| +495ms |
║║Calculating (string) Corner Go,on,68,259 + (string) , >> (string) Corner Go,on,68,259, |
| +498ms |
║║Calculating (string) Corner Go,on,68,259, + (string) 100 >> (string) Corner Go,on,68,259,100 |
| +503ms |
║║Executed virtual command setVariable (3ms) |
| +512ms |
| +523ms |
║║Executed virtual command [Couch Lightstrip 1].setVariable (3ms) |
| +534ms |
║║Executed virtual command [Couch Lightstrip 1].setVariable (4ms) |
| +543ms |
| +553ms |
| +560ms |
║║Comparison (decimal) 1.0 is_equal_to (integer) 0 = false (2ms) |
| +561ms |
| +562ms |
║║Condition #19 evaluated false (6ms) |
| +563ms |
| +564ms |
║║Condition group #14 evaluated false (state changed) (8ms) |
| +566ms |
║║Cancelling statement #15’s schedules… |
| +580ms |
║║Calculating (string) Corner Go,on,68,259,100 + (string) , >> (string) Corner Go,on,68,259,100, |
| +584ms |
║║Calculating (string) Corner Go,on,68,259,100, + (string) Couch Lightstrip 1 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1 |
| +588ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1, |
| +591ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on |
| +595ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on, |
| +598ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68 |
| +601ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68, |
| +603ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68, + (string) 266 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266 |
| +606ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266, |
| +608ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266, + (string) 86 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86 |
| +614ms |
| +624ms |
| +636ms |
║║Executed virtual command [Couch Lightstrip 2].setVariable (3ms) |
| +646ms |
| +655ms |
| +664ms |
| +670ms |
║║Comparison (decimal) 2.0 is_equal_to (integer) 0 = false (1ms) |
| +672ms |
║║Condition #19 evaluated false (5ms) |
| +673ms |
║║Condition group #14 evaluated false (state did not change) (5ms) |
| +675ms |
| +687ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86, |
| +691ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86, + (string) Couch Lightstrip 2 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2 |
| +695ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2, |
| +698ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on |
| +701ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on, |
| +704ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68 |
| +707ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68, |
| +710ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68, + (string) 334 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334 |
| +713ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334, |
| +715ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334, + (string) 100 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100 |
| +721ms |
| +730ms |
| +745ms |
║║Executed virtual command [Lamp 1].setVariable (4ms) |
| +756ms |
║║Executed virtual command [Lamp 1].setVariable (5ms) |
| +766ms |
║║Executed virtual command [Lamp 1].setVariable (3ms) |
| +776ms |
| +782ms |
║║Comparison (decimal) 3.0 is_equal_to (integer) 0 = false (1ms) |
| +784ms |
| +785ms |
| +787ms |
| +799ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100, |
| +803ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100, + (string) Lamp 1 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1 |
| +807ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1, |
| +810ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on |
| +814ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on, |
| +817ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68 |
| +820ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68, |
| +823ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68, + (string) 259 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259 |
| +825ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259, |
| +827ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259, + (string) 100 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100 |
| +833ms |
| +842ms |
| +854ms |
║║Executed virtual command [Lamp 2].setVariable (3ms) |
| +863ms |
║║Executed virtual command [Lamp 2].setVariable (4ms) |
| +872ms |
| +880ms |
║║Executed virtual command [Lamp 2].setVariable (2ms) |
| +887ms |
║║Comparison (decimal) 4.0 is_equal_to (integer) 0 = false (2ms) |
| +888ms |
| +889ms |
║║Condition group #14 evaluated false (state did not change) (6ms) |
| +892ms |
| +905ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100, |
| +909ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100, + (string) Lamp 2 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2 |
| +913ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2, |
| +916ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on |
| +920ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on, |
| +923ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68 |
| +926ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68, |
| +928ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68, + (string) 259 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259 |
| +931ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259, |
| +933ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259, + (string) 100 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100 |
| +940ms |
║║Executed virtual command setVariable (4ms) |
| +949ms |
| +961ms |
║║Executed virtual command [Shelf].setVariable (4ms) |
| +971ms |
║║Executed virtual command [Shelf].setVariable (3ms) |
| +982ms |
| +990ms |
| +996ms |
║║Comparison (decimal) 5.0 is_equal_to (integer) 0 = false (1ms) |
| +998ms |
| +999ms |
| +1001ms |
| +1012ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100, |
| +1016ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100, + (string) Shelf >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf |
| +1020ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf, |
| +1024ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on |
| +1027ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on, |
| +1030ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68 |
| +1033ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68, |
| +1036ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68, + (string) 198 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198 |
| +1038ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198, |
| +1040ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198, + (string) 85 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85 |
| +1045ms |
| +1054ms |
| +1064ms |
║║Executed virtual command [TV Lightstrip].setVariable (2ms) |
| +1073ms |
║║Executed virtual command [TV Lightstrip].setVariable (4ms) |
| +1082ms |
║║Executed virtual command [TV Lightstrip].setVariable (3ms) |
| +1090ms |
| +1096ms |
║║Comparison (decimal) 6.0 is_equal_to (integer) 0 = false (2ms) |
| +1097ms |
| +1098ms |
| +1100ms |
| +1111ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85, |
| +1116ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85, + (string) TV Lightstrip >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip |
| +1119ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip, |
| +1123ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip, + (string) on >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on |
| +1126ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on, |
| +1129ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on, + (string) 68 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68 |
| +1132ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68, |
| +1135ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68, + (string) 334 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68,334 |
| +1137ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68,334 + (string) , >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68,334, |
| +1139ms |
║║Calculating (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68,334, + (string) 87 >> (string) Corner Go,on,68,259,100,Couch Lightstrip 1,on,68,266,86,Couch Lightstrip 2,on,68,334,100,Lamp 1,on,68,259,100,Lamp 2,on,68,259,100,Shelf,on,68,198,85,TV Lightstrip,on,68,334,87 |
| +1144ms |
| +1148ms |
║║Cancelling statement #12’s schedules… |
| +1160ms |
| +1165ms |
| +1190ms |
║║Sending internal web request to: MY WEBSERVER |
| +1199ms |
║║Executed virtual command httpRequest (27ms) |
| +1203ms |
║║Requesting a wake up for Tue, Jul 10 2018 @ 11:35:23 PM PDT (in 20.0s) |
| +1247ms |
║╚Execution stage complete. (921ms) |
| +1270ms |
║Setting up scheduled job for Tue, Jul 10 2018 @ 11:35:24 PM PDT (in 19.938s) |
| +1278ms |
╚Event processed successfully (1277ms) |
