Running Out of WebCore Space
I’m not sure what category to post this is but I’ve got a total of 250+ Pistons automating over 200 devices on SmartThings. I’m current at 90% full on my WebCore space limit. How do I go about getting more space? Can I create another instance of WebCore?
Thank you
Shane
Yes you can and a good solution for you…
https://wiki.webcore.co/Multiple_Instances
Thanks for the advice. This should help me out immensely.
As any FYI on the HE port, webCoRE uses state much less. So there are limits, but the usage per piston has been removed from state.
