I tied to tidy up my piston and think I broke it. Now one works fine but the other turns off then back on, it also flashes sometimes. It also changes colour when the restrictions are true.
Turn the lights on off and stay insync with ST, if the conditions are met it should set the colour temp as well. If in party mode it will also randomly change colour.
Light turns off, then turns back on with different color temperature, then most of the time turns back off then back on.
not working piston
working piston
ded0a530-293b-4a66-9e04-78ba3854e951 20:46:10: debug [raw:0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:B1A8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[89, 00, 00, 00], clusterInt:8, commandInt:7] ded0a530-293b-4a66-9e04-78ba3854e951 20:46:10: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:10: debug description is catchall: 0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:08: debug [raw:0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6A00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B1A8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6A, 00], clusterInt:32801, commandInt:0] ded0a530-293b-4a66-9e04-78ba3854e951 20:46:08: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6A00 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:08: debug description is catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6A00 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:06: warn ON/OFF REPORTING CONFIG FAILED- error code:137 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:06: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:04: debug [raw:0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6900, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B1A8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[69, 00], clusterInt:32801, commandInt:0] ded0a530-293b-4a66-9e04-78ba3854e951 20:46:04: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6900 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:04: debug description is catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6900 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:02: debug description is read attr - raw: B1A80303000A0100002000, dni: B1A8, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: 00 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:00: debug description is read attr - raw: B1A80303000A0000002000, dni: B1A8, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, result: success, encoding: 20, value: 00 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:00: debug [raw:0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:B1A8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[89, 00, 00, 00], clusterInt:8, commandInt:7] ded0a530-293b-4a66-9e04-78ba3854e951 20:46:00: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:46:00: debug description is catchall: 0104 0008 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:58: debug [name:level, value:100] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:58: debug description is read attr - raw: B1A80300080A00000020FE, dni: B1A8, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, result: success, encoding: 20, value: fe ded0a530-293b-4a66-9e04-78ba3854e951 20:45:58: warn ON/OFF REPORTING CONFIG FAILED- error code:137 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:58: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 07 01 89000000 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:57: debug [name:switch, value:on] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:57: debug description is on/off: 1 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:57: debug [name:level, value:100] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:57: debug description is read attr - raw: B1A803000808000020FE, dni: B1A8, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug [name:switch, value:off] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 01 01 0000001000 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug [name:switch, value:off] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 0B 01 0000 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug [name:level, value:1] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug description is read attr - raw: B1A80300080800002001, dni: B1A8, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 01 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug [name:switch, value:off] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug description is on/off: 0 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug [raw:0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6500, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B1A8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[65, 00], clusterInt:32801, commandInt:0] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6500 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:54: debug description is catchall: 0000 8021 00 00 0040 00 B1A8 00 00 0000 00 00 6500 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:52: debug description is read attr - raw: B1A80303000A0100002000, dni: B1A8, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: 00 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:50: debug description is read attr - raw: B1A80303000A0000002000, dni: B1A8, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, result: success, encoding: 20, value: 00 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:48: debug [name:colorTemperature, value:2703] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:48: debug description is read attr - raw: B1A80303000C070000217201, dni: B1A8, endpoint: 03, cluster: 0300, size: 0C, attrId: 0007, result: success, encoding: 21, value: 0172 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:46: debug [name:level, value:100] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:46: debug description is read attr - raw: B1A80300080A00000020FE, dni: B1A8, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, result: success, encoding: 20, value: fe ded0a530-293b-4a66-9e04-78ba3854e951 20:45:45: debug [name:level, value:100] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:45: debug description is read attr - raw: B1A803000808000020FE, dni: B1A8, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug [name:switch, value:on] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 01 01 0000001001 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug [name:switch, value:on] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug description is catchall: 0104 0006 03 01 0040 00 B1A8 00 00 0000 0B 01 0100 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug [name:switch, value:on] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug description is on/off: 1 ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug [name:level, value:1] ded0a530-293b-4a66-9e04-78ba3854e951 20:45:44: debug description is read attr - raw: B1A80300080800002001, dni: B1A8, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 01
hope this helps!
