I have a gas fireplace that uses a simple continuity contact for control. It has a panel mount SPST switch and a RF remote for control.
I wired in a FortrezZ MIMOLite such that the input reads when the RF control relay closes and the MIMO relay is wired in parallel with the switch allowing either to turn the fireplace on.
I’ve put together a piston that does a few things:
- If the RF remote controlled relay turns on the piston turns on the MIMO relay which turns on the fireplace
- If the RF remote controlled relay turns off the piston turns off the MIMO relay which turns off the fireplace
- If the switch stays on for more than 4 hours OR the motion sensor in the room is inactive for more than 1 hour OR the temp sensor in the room stays above 72F for 1 minute the piston turns off the MIMO relay and notifies me.
Did I wire this whole thing up correctly?
