This is true if they are indeed triggers like line 36, but line 38 & 40 are conditions, so it will still fire based on contact if @MLUCK does not follow the advice in your last post.
In a nutshell, only one lightning bolt per block is ideal, with as many conditions below that as you want.
(the exception is when triggers are connected with the word “or” like line 21)
