If I have an action that is set to occur at 5:58 am it usually does not execute properly
At 5:58am I want to change the house temperature to the usual daytime settings.
The piston does not show in the logs as starting at 5:58. Instead I see a “recovery” item that starts sometimes as much as 90 seconds later. However, when that second instance gets to the 5:58 am statement it fails because it is now 5:59:30. I can’t be the only person having this problem. Has anyone else worked a solution? I am sorry I don’t have the image of the piston script, but I have re-edited it so many times trying other ideas. However the faulty statement is simply a "if happens daily at 5:58am then " set the temperature.
You can see from the log snippet that not only is there no entry at 5:58am, but the 5:59:30am recovery instance fails because 5:58 has passed.
** 5) Attach logs after turning logging level to Full**
╔Received event [Jeppsen Home].execute = recovery with a delay of 62ms
+185ms ║RunTime Analysis CS > 20ms > PS > 109ms > PE > 55ms > CE
+188ms ║Runtime (49873 bytes) successfully initialized in 109ms (v0.3.110.20191009) (186ms)
+189ms ║╔Execution stage started
+197ms ║║Comparison (time) 21563254 happens_daily_at (time) 21480000 = false (0ms)
