I am trying to obtain some additional information regarding the capability of WebCoRE to control some of the settings of the Schlage Z-Wave Connect Century (BE469). Anyone not familiar with the lock, it has a setting called Lock and Leave where hitting the Schalge button on the outside locks the door. Very quick and easy way to lock the door when leaving which does not require the pass code to be inputted to lock the door.
I am trying to have WebCore control this setting. The following command appears in WebCore: setLockLeave. I have tried taking the values which appear in the IDE for the set lockleave setting (off_lockLeave and on_lockLeave) as an integer to automate this process but it does not seem to work.
Example: Having a guest code inputted turns on a virtual presence sensor for the home and disables lock and leave so that when the guest leaves they have to input the code again (Not simply hit the Schlage button on outside) to lock the door. The code being input again by the guest would turn off guest mode and re-enable lock and leave setting. As a daily user I like the one touch lock settings, but I want that to automatically be disabled if a guest code is entered.
The code is turning the virtual guest presence sensor on and off appropriately, but there is no change to the Lock Leave setting (Disabled and re-enabling).
