Here’s an example piston of how to send push notifications using the Pushbullet API. First off you need to go to your account settings and create an access token.
https://www.pushbullet.com/#settings/account
You’ll then modify the expression and add your access token here.
In this sample piston.
Be sure to use the following for the URL:
