“Should it do anything else apart from say which door has been opened?”
I should of added, in the sample, I sent a msg to my sonos speakers and a pushover alert
could remove the sonos speakers part if just testing the pushover stuff
I moved this into feature suggestions category. But,@John68 and/or @ipaterson if you’re willing to do a single write up and/or video tutorial, this would be a big community asset, and that would have a great home in the tutorials category!
I am just learning myself, ipaterson was the one that came up with the way to make it happen
I’m going to start by working on an example of the Smart notify piston using Pushover, but there would be value in some generic advice as well, thanks for the suggestion.
Is there a way to have multiple messages for different if/then statements to choose from within 1 piston? (newbie here)
Did you ever figure this out? I want to accomplish the same thing but am having trouble…
I’ve used this very often - it’s great. However, due to the changes in Smartthings, I’m moving to Hubitat. So I tried to copy this to WebCore, but can’t seem to get i working. Should anything be different for doing this with WebCore in Hubitat?
In Hubitat, there is a native pushover driver.
You have to create a device for it
HE console -> devices -> + Add Device -> Virtual -> scroll down to Pushover driver
then configure it with your keys, etc.
Now you can use it in various apps, etc.
Thanks for your reply.
Yes, I know. But I just really like this solution and was confused about why it wouldn’t work. It ought to just by adding a new token? But does not.
I want to send to two or three different users, so I can separate the notifications.
There is another community written driver you can consider:
You can ask a question in the HE forum more specifically to what you want the device handler to be able to do.
Otherwise post your piston (or a private message if you think webcore is mis-behaving, and I can take a look for HE).
