I’ve been trying to get a simple piston (garage door monitor related) to work, but am having problems with something that seems basic and might be bug related.
First, I notice that when I select “sensor” as the capability, the “sensor list” I am given includes not only my sensors but all of my devices. Second, I find that regardless of which sensor I select as the test condition I can not get the piston to evaluate as true. In confirming that, I switched to the comparison being “changes” - should should yield a true evaluation more easily on any sensor state change (I presume) – but still I don’t get the piston to trigger.
(I can get a true evaluation when I select a switch and test for change, but that doesn’t help my use case;-).
So to me this behavior implies a bug somewhere. Not sure where to take this for further help, confirm the bug or other workarounds…
I’m wondering if anyone else sees “non-sensor devices” being reported under the sensor capability list?
