I want to create a piston that alerts us if a window or door has been left open when we leave. I was using the ST phone presence to activate the piston. But it is too slow or unreliable. As we leave we go through a sequence: we walk through the laundry room, which has a motion sensor; then open the garage door; then close the garage door. I thought if I could create a piston that looks for that exact sequence, I could use that to send an alert if a window or door is open. It will need to send the alert immediately after the garage door closes … as we want the alert before we drive away.
This could be useful for several circumstances. For instance, a bedtime routine. If a sequence of motion sensors were activated going up the stairs, after the lounge lights were turned off.
Can webCore look for an exact sequence?
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
