Is there a way to set the state of a Dimmer level to 100% without turning the light on. I am using all LED lights and would prefer not to see all the lights flash at 100%. The switch obviously retains the level it was last at, I just want to go in and make that level 100% that way whenever someone walks up and turns the switch on it will go to 100%.
11/8/2019, 4:31:11 AM +121ms
+1ms ╔Received event [Home].time = 1573216272143 with a delay of -1022ms
+167ms ║RunTime Analysis CS > 67ms > PS > 56ms > PE > 44ms > CE
+170ms ║Runtime (47061 bytes) successfully initialized in 56ms (v0.3.110.20191009) (168ms)
+171ms ║╔Execution stage started
+172ms ║╚Execution stage complete. (1ms)
+173ms ╚Event processed successfully (173ms)
11/8/2019, 4:31:07 AM +200ms
+1ms ╔Received event [Light Hallway Dimmer].switch = off with a delay of 119ms
+124ms ║RunTime Analysis CS > 24ms > PS > 50ms > PE > 51ms > CE
+127ms ║Runtime (47063 bytes) successfully initialized in 50ms (v0.3.110.20191009) (125ms)
+128ms ║╔Execution stage started
+137ms ║║Cancelling condition #9’s schedules…
+138ms ║║Condition #9 evaluated false (6ms)
+139ms ║║Condition group #3 evaluated false (state did not change) (8ms)
+147ms ║║Cancelling condition #21’s schedules…
+148ms ║║Condition #21 evaluated false (6ms)
+149ms ║║Cancelling condition #15’s schedules…
+150ms ║║Condition group #15 evaluated false (state changed) (9ms)
+155ms ║║Comparison (enum) off changes_to (string) off = true (1ms)
+156ms ║║Cancelling condition #28’s schedules…
+157ms ║║Condition #28 evaluated true (5ms)
+158ms ║║Cancelling condition #25’s schedules…
+159ms ║║Condition group #25 evaluated true (state changed) (7ms)
+161ms ║║Cancelling statement #26’s schedules…
+167ms ║║Executed virtual command setVariable (3ms)
+171ms ║║Code Line 81 completed
+176ms ║║Executed virtual command log (4ms)
+182ms ║╚Execution stage complete. (55ms)
+183ms ╚Event processed successfully (183ms)
11/8/2019, 4:31:05 AM +170ms
+1ms ╔Received event [Home].time = 1573216266293 with a delay of -1123ms
+796ms ║RunTime Analysis CS > 75ms > PS > 120ms > PE > 600ms > CE
+799ms ║Runtime (47060 bytes) successfully initialized in 120ms (v0.3.110.20191009) (797ms)
+800ms ║╔Execution stage started
+1967ms ║║Executed physical command [Light Hallway Dimmer].setLevel([0]) (582ms)
+1968ms ║║Executed [Light Hallway Dimmer].setLevel (584ms)
+1971ms ║║Executed virtual command [Light Hallway Dimmer].wait (1ms)
+1973ms ║║Requesting a wake up for Fri, Nov 8 2019 @ 4:31:12 AM PST (in 5.0s)
+1977ms ║╚Execution stage complete. (1178ms)
+1979ms ║Setting up scheduled job for Fri, Nov 8 2019 @ 4:31:12 AM PST (in 4.995s)
+1987ms ╚Event processed successfully (1987ms)
11/8/2019, 4:30:57 AM +901ms
+1ms ╔Received event [Motion/Light Sensor Hall].motion = inactive with a delay of 147ms
+103ms ║RunTime Analysis CS > 18ms > PS > 44ms > PE > 41ms > CE
+106ms ║Runtime (47075 bytes) successfully initialized in 44ms (v0.3.110.20191009) (104ms)
+113ms ║║Comparison (enum) inactive changes = true (1ms)
+114ms ║║Cancelling condition #9’s schedules…
+115ms ║║Condition #9 evaluated true (4ms)
+123ms ║║Comparison (enum) on is (string) off = false (1ms)
+125ms ║║Cancelling condition #32’s schedules…
+125ms ║║Condition #32 evaluated false (9ms)
+126ms ║║Condition group #3 evaluated false (state did not change) (16ms)
+132ms ║║Comparison (enum) inactive changes_to (string) inactive = true (1ms)
+133ms ║║Cancelling condition #21’s schedules…
+134ms ║║Condition #21 evaluated true (5ms)
+138ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+139ms ║║Condition #24 evaluated true (4ms)
+140ms ║║Cancelling condition #15’s schedules…
+141ms ║║Condition group #15 evaluated true (state changed) (13ms)
+143ms ║║Cancelling statement #46’s schedules…
+159ms ║║Executed virtual command [Light Hallway Dimmer].wait (1ms)
+168ms ║║Skipped execution of physical command [Light Hallway Dimmer].setLevel([60]) because it would make no change to the device. (6ms)
+169ms ║║Executed [Light Hallway Dimmer].setLevel (8ms)
+172ms ║║Executed virtual command [Light Hallway Dimmer].wait (1ms)
+173ms ║║Waiting for 1000ms
+1288ms ║║Executed physical command [Light Hallway Dimmer].setLevel([50]) (112ms)
+1289ms ║║Executed [Light Hallway Dimmer].setLevel (113ms)
+1292ms ║║Executed virtual command [Light Hallway Dimmer].wait (1ms)
+1293ms ║║Waiting for 1000ms
+2334ms ║║Executed physical command [Light Hallway Dimmer].setLevel([30]) (38ms)
+2335ms ║║Executed [Light Hallway Dimmer].setLevel (40ms)
+2339ms ║║Executed virtual command [Light Hallway Dimmer].wait (0ms)
+2339ms ║║Waiting for 1000ms
+3386ms ║║Executed physical command [Light Hallway Dimmer].setLevel([10]) (43ms)
+3387ms ║║Executed [Light Hallway Dimmer].setLevel (45ms)
+3390ms ║║Executed virtual command [Light Hallway Dimmer].wait (1ms)
+3391ms ║║Requesting a wake up for Fri, Nov 8 2019 @ 4:31:06 AM PST (in 5.0s)
+3395ms ║╚Execution stage complete. (3289ms)
+3396ms ║Setting up scheduled job for Fri, Nov 8 2019 @ 4:31:06 AM PST (in 4.996s)
+3405ms ╚Event processed successfully (3405ms)
11/8/2019, 4:30:43 AM +527ms
+1ms ╔Received event [Light Hallway Dimmer].switch = on with a delay of 64ms
+9867ms ║RunTime Analysis CS > 20ms > PS > 9802ms > PE > 45ms > CE
+9868ms ║Piston waited at a semaphore for 9770ms
+9871ms ║Runtime (47136 bytes) successfully initialized in 9802ms (v0.3.110.20191009) (9869ms)
+9872ms ║╔Execution stage started
+9882ms ║║Cancelling condition #9’s schedules…
+9883ms ║║Condition #9 evaluated false (7ms)
+9884ms ║║Cancelling condition #3’s schedules…
+9885ms ║║Condition group #3 evaluated false (state changed) (9ms)
+9893ms ║║Condition #21 evaluated false (6ms)
+9894ms ║║Condition group #15 evaluated false (state did not change) (7ms)
+9899ms ║║Comparison (enum) on changes_to (string) off = false (0ms)
+9901ms ║║Condition #28 evaluated false (3ms)
+9902ms ║║Condition group #25 evaluated false (state did not change) (5ms)
+9903ms ║╚Execution stage complete. (32ms)
+9905ms ╚Event processed successfully (9904ms)
11/8/2019, 4:30:43 AM +214ms
+2ms ╔Received event [Motion/Light Sensor Hall].motion = active with a delay of 164ms
+100ms ║RunTime Analysis CS > 18ms > PS > 43ms > PE > 39ms > CE
+103ms ║Runtime (47074 bytes) successfully initialized in 43ms (v0.3.110.20191009) (101ms)
+111ms ║║Comparison (enum) active changes = true (0ms)
+112ms ║║Cancelling condition #9’s schedules…
+113ms ║║Condition #9 evaluated true (4ms)
+120ms ║║Comparison (enum) off is (string) off = true (1ms)
+122ms ║║Cancelling condition #32’s schedules…
+123ms ║║Condition #32 evaluated true (9ms)
+124ms ║║Cancelling condition #3’s schedules…
+124ms ║║Condition group #3 evaluated true (state changed) (16ms)
+127ms ║║Cancelling statement #29’s schedules…
+132ms ║║Executed virtual command [Light Hallway Dimmer].setVariable (3ms)
+285ms ║║Executed physical command [Light Hallway Dimmer].setLevel([60]) (125ms)
+286ms ║║Executed [Light Hallway Dimmer].setLevel (126ms)
+291ms ║║Motion Turned Light on
+292ms ║║Executed virtual command [Light Hallway Dimmer].log (1ms)
+298ms ║║Comparison (enum) active changes_to (string) inactive = false (1ms)
+299ms ║║Condition #21 evaluated false (4ms)
+300ms ║║Condition group #15 evaluated false (state did not change) (5ms)
+308ms ║║Cancelling condition #28’s schedules…
+309ms ║║Condition #28 evaluated false (6ms)
+310ms ║║Cancelling condition #25’s schedules…
+311ms ║║Condition group #25 evaluated false (state changed) (9ms)
+313ms ║╚Execution stage complete. (209ms)
+314ms ╚Event processed successfully (314ms)
