Problem:
When Set Variable is called, the variable remains as the default value and does not change.
Snapshot:
Logs: (the relevant parts)
|+388ms|║║Condition group #10 evaluated true (state did not change) (9ms)|
|+389ms|║║Cancelling statement #12's schedules...|
|+394ms|║║Executed virtual command setVariable (1ms)|
|+397ms|║║Cancelling statement #14's schedules...|
|+484ms|║║Executed physical command [Entry].on() (83ms)|
|+485ms|║║Executed [Entry].on (85ms)|
I checked the logs. The variable is not getting reset anywhere that I can tell. It just simply isn’t changing to begin with.
