Hi guys,
Please see attached a snapshot of my piston.
Everything works on it, all the complex stuff - but for some reason the simpliest thing doesn’t work. In the first part it runs a section based on if "dontCheck = 0"in that section it tries to set dontCheck to 1 - for some reason this never works though and it won’t set it as 1.
If I test it in the last part (where it resets dontCheck to 0 again just after midnight each night) I can change it to 0 or 1 no problem there. But for some reason it won’t work in the section near the start - which runs all the other API checks and sets the battery level variable with no problems.
Any ideas why, is this a bug?
