I have a few window contacts, that I want to change the radiator heat level.
I would like to have so that when a certain window opens a specific thermostat changes value. f.x. shuts off and when the window i closed again it turn on to a predefined heat level.
I have the heating level working in another script using a lot of if sentences. So I wanted to minimize code using CASE.
I am not certain on how to make it work correctly. I can make the code send me a PUSH msg when opening the “kontor” window but when trying the second CASE (Terrassedør) it sends a message from “Vindue kontor”. I somehow does not match the CASE.
╔Received event [Terrassedør stue].contact = closed with a delay of 42ms
+33ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 17ms > CE
+35ms ║Runtime (40829 bytes) successfully initialized in 4ms (v0.3.113.20210203) (34ms)
+36ms ║╔Execution stage started
+160ms ║║Evaluating switch with values [i::b97623c7fcb8f38dc70981fe6a1de680::contact, v:[t:enum, v:closed, d::b97623c7fcb8f38dc70981fe6a1de680:, a:contact, i:null, x:false, vt:string]], [i::98a2facbeb7efb8ca36f27e6f4b7237a::contact, v:[t:enum, v:closed, d::98a2facbeb7efb8ca36f27e6f4b7237a:, a:contact, i:null, x:false, vt:string]], [i::a13c35817f4c5febe22fd0066208cac6::contact, v:[t:enum, v:open, d::a13c35817f4c5febe22fd0066208cac6:, a:contact, i:null, x:false, vt:string]], [i::ce17814dfbee435ce760850d194d5549::contact, v:[t:enum, v:closed, d::ce17814dfbee435ce760850d194d5549:, a:contact, i:null, x:false, vt:string]], [i::5e2fc5c890dccf6483b2dcd0aca8f174::contact, v:[t:enum, v:closed, d::5e2fc5c890dccf6483b2dcd0aca8f174:, a:contact, i:null, x:false, vt:string]], [i::c0072808e0ff9461b97eb2281ba906e1::contact, v:[t:enum, v:open, d::c0072808e0ff9461b97eb2281ba906e1:, a:contact, i:null, x:false, vt:string]], i::2b8f4c949a31f33081d27449fcf7e1af::contact, v:t:enum, v:closed, d::2b8f4c949a31f33081d27449fcf7e1af:, a:contact…[TRUNCATED]
+166ms ║║Comparison (enum) closed is (enum) closed = true (2ms)
+176ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+178ms ║║Condition #4 evaluated true (10ms)
+180ms ║║Condition group #3 evaluated true (state did not change) (12ms)
+182ms ║║Cancelling statement #7’s schedules…
+196ms ║║Executed virtual command sendPushNotification (8ms)
+201ms ║╚Execution stage complete. (164ms)
+202ms ╚Event processed successfully (202ms)
19.9.2021 18.29.23 +498ms
+1ms ╔Received event [Terrassedør stue].contact = open with a delay of 65ms
+41ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 20ms > CE
+44ms ║Runtime (40829 bytes) successfully initialized in 5ms (v0.3.113.20210203) (42ms)
+45ms ║╔Execution stage started
+79ms ║║Evaluating switch with values [i::b97623c7fcb8f38dc70981fe6a1de680::contact, v:[t:enum, v:closed, d::b97623c7fcb8f38dc70981fe6a1de680:, a:contact, i:null, x:false, vt:string]], [i::98a2facbeb7efb8ca36f27e6f4b7237a::contact, v:[t:enum, v:open, d::98a2facbeb7efb8ca36f27e6f4b7237a:, a:contact, i:null, x:false, vt:string]], [i::a13c35817f4c5febe22fd0066208cac6::contact, v:[t:enum, v:open, d::a13c35817f4c5febe22fd0066208cac6:, a:contact, i:null, x:false, vt:string]], [i::ce17814dfbee435ce760850d194d5549::contact, v:[t:enum, v:closed, d::ce17814dfbee435ce760850d194d5549:, a:contact, i:null, x:false, vt:string]], [i::5e2fc5c890dccf6483b2dcd0aca8f174::contact, v:[t:enum, v:closed, d::5e2fc5c890dccf6483b2dcd0aca8f174:, a:contact, i:null, x:false, vt:string]], [i::c0072808e0ff9461b97eb2281ba906e1::contact, v:[t:enum, v:open, d::c0072808e0ff9461b97eb2281ba906e1:, a:contact, i:null, x:false, vt:string]], i::2b8f4c949a31f33081d27449fcf7e1af::contact, v:t:enum, v:closed, d::2b8f4c949a31f33081d27449fcf7e1af:, a:contact, …[TRUNCATED]
+86ms ║║Comparison (enum) closed is (enum) closed = true (2ms)
+95ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+97ms ║║Condition #4 evaluated true (9ms)
+98ms ║║Condition group #3 evaluated true (state did not change) (10ms)
+101ms ║║Cancelling statement #7’s schedules…
+127ms ║║Executed virtual command sendPushNotification (21ms)
+130ms ║╚Execution stage complete. (85ms)
+131ms ╚Event processed successfully (131ms)
19.9.2021 18.28.40 +223ms
+1ms ╔Received event [Vindue kontor].contact = closed with a delay of 81ms
+59ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 36ms > CE
+62ms ║Runtime (40826 bytes) successfully initialized in 6ms (v0.3.113.20210203) (60ms)
+63ms ║╔Execution stage started
+96ms ║║Evaluating switch with values [i::b97623c7fcb8f38dc70981fe6a1de680::contact, v:[t:enum, v:closed, d::b97623c7fcb8f38dc70981fe6a1de680:, a:contact, i:null, x:false, vt:string]], [i::98a2facbeb7efb8ca36f27e6f4b7237a::contact, v:[t:enum, v:closed, d::98a2facbeb7efb8ca36f27e6f4b7237a:, a:contact, i:null, x:false, vt:string]], [i::a13c35817f4c5febe22fd0066208cac6::contact, v:[t:enum, v:open, d::a13c35817f4c5febe22fd0066208cac6:, a:contact, i:null, x:false, vt:string]], [i::ce17814dfbee435ce760850d194d5549::contact, v:[t:enum, v:closed, d::ce17814dfbee435ce760850d194d5549:, a:contact, i:null, x:false, vt:string]], [i::5e2fc5c890dccf6483b2dcd0aca8f174::contact, v:[t:enum, v:closed, d::5e2fc5c890dccf6483b2dcd0aca8f174:, a:contact, i:null, x:false, vt:string]], [i::c0072808e0ff9461b97eb2281ba906e1::contact, v:[t:enum, v:open, d::c0072808e0ff9461b97eb2281ba906e1:, a:contact, i:null, x:false, vt:string]], i::2b8f4c949a31f33081d27449fcf7e1af::contact, v:t:enum, v:closed, d::2b8f4c949a31f33081d27449fcf7e1af:, a:contact…[TRUNCATED]
+101ms ║║Comparison (enum) closed is (enum) closed = true (1ms)
+108ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+110ms ║║Cancelling condition #4’s schedules…
+111ms ║║Condition #4 evaluated true (8ms)
+113ms ║║Cancelling condition #3’s schedules…
+114ms ║║Condition group #3 evaluated true (state changed) (11ms)
+117ms ║║Cancelling statement #7’s schedules…
+135ms ║║Executed virtual command sendPushNotification (11ms)
+138ms ║╚Execution stage complete. (75ms)
+140ms ╚Event processed successfully (140ms)
19.9.2021 18.28.33 +631ms
+1ms ╔Received event [Vindue kontor].contact = open with a delay of 46ms
+32ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 15ms > CE
+34ms ║Runtime (40826 bytes) successfully initialized in 4ms (v0.3.113.20210203) (32ms)
+35ms ║╔Execution stage started
+89ms ║║Evaluating switch with values [i::b97623c7fcb8f38dc70981fe6a1de680::contact, v:[t:enum, v:closed, d::b97623c7fcb8f38dc70981fe6a1de680:, a:contact, i:null, x:false, vt:string]], [i::98a2facbeb7efb8ca36f27e6f4b7237a::contact, v:[t:enum, v:closed, d::98a2facbeb7efb8ca36f27e6f4b7237a:, a:contact, i:null, x:false, vt:string]], [i::a13c35817f4c5febe22fd0066208cac6::contact, v:[t:enum, v:open, d::a13c35817f4c5febe22fd0066208cac6:, a:contact, i:null, x:false, vt:string]], [i::ce17814dfbee435ce760850d194d5549::contact, v:[t:enum, v:closed, d::ce17814dfbee435ce760850d194d5549:, a:contact, i:null, x:false, vt:string]], [i::5e2fc5c890dccf6483b2dcd0aca8f174::contact, v:[t:enum, v:open, d::5e2fc5c890dccf6483b2dcd0aca8f174:, a:contact, i:null, x:false, vt:string]], [i::c0072808e0ff9461b97eb2281ba906e1::contact, v:[t:enum, v:open, d::c0072808e0ff9461b97eb2281ba906e1:, a:contact, i:null, x:false, vt:string]], i::2b8f4c949a31f33081d27449fcf7e1af::contact, v:t:enum, v:closed, d::2b8f4c949a31f33081d27449fcf7e1af:, a:contact, …[TRUNCATED]
+93ms ║║Comparison (enum) closed is (enum) open = false (1ms)
+95ms ║║Comparison (enum) closed is (enum) open = false (1ms)
+98ms ║║Comparison (enum) open is (enum) open = true (1ms)
+104ms ║║Comparison (enum) open is (string) closed = false (1ms)
+106ms ║║Cancelling condition #4’s schedules…
+107ms ║║Condition #4 evaluated false (7ms)
+109ms ║║Cancelling condition #3’s schedules…
+110ms ║║Condition group #3 evaluated false (state changed) (9ms)
+112ms ║║Cancelling statement #20’s schedules…
+125ms ║║Executed virtual command sendPushNotification (8ms)
+202ms ║╚Execution stage complete. (167ms)
+204ms ╚Event processed successfully (203ms)
