Hi all. I have read about the benefits of more shorter pistons then one long one but I’m not quite sure what to do here. I’ve posted but it’s probably easier to explain. I have a piston where the trigger is the unlocking of my front door. From there, there are two conditions (presence and a virtual goodbye switch). If I unlock then if I am present and the v switch is on, there are then 3 blocks of time of day where different actions will occur. If I am present and the v switch is off, different things happen. Finally if the vswitch is on, but I am not present and someone unlocks the door, a set of different actions occur.
So as you can imagine there is a lot of Boolean logic. I didn’t know if it was better to somehow have separate pistons but thought the door unlocking triggering say 3 or 4 different pistons would make less sense from an overall efficiency standpoint. Overall it just looks messy.
(PUT YOUR INFO HERE)
