Show House Mode in Dashboard
I have no idea if this has been accomplished but preliminary searching is not uplifting. Right now, just looking for brainstorming…or anyone who may have already cracked this egg.
I would like to show the current home mode in the dashboard.
A multi-variable switch of some kind that can show more than just on or off.
Not sure where to start. Would need to define virtual device that is capable of more than boolean. Like a temp sensor. Except instead of providing numeric values, could be provided text. This device would then be added to favorites.
***) My workaround for this absence would be to create two virtual switches, one for home/away and the other for day/night. Update these via WebCore using home mode changes. The downside is this gives me only 4 modes.
Thanks
What dashboard are you talking about? It can’t be the webCoRE dashboard, right, cause that’s already there.
Do you mean the phone app? Help me understand the question.
My apologies, I am referring to the SmartThings iOS dashboard. This is my “front end” for the family.
How many modes do you use?
If 4 or less you could use a simulated device with garage door capability (which allows for 4 states)
Primarily just 4 regular modes: Home, Away, Night & Night (Away). I also have an Emergency (All lights on) and Party (which basically will just override automatic off routines). Fairly simple “I think”. I have punted the vacation mode, because after thinking through my long term plans, there is nothing I need there that is not accomplished between Away and Away (Night). I run a lot lighting routines based on morning (wakeup or sunrise) and evening (sunset) times, but I decided to do these events without a dedicated mode, as it was complicating things more than necessary.
I will check out your suggested, thanks!
