Just add variable (local) that countain expression like: ( var_A = var_B + var_C). The variable Var_A show the expression in the piston but I want it to show the result!
see result like if B=2 & C =3 then (Var_A = 5)
see the expression Var_A = Var_B + Var_C
No ideas of the result as long as I evaluate myself or edit the expression to get the evaluation…
(UPLOAD YOUR IMAGE HERE)
