It is not running during the scheduled time.
This is a very simplified version of Bangali’s Holiday Lights piston. This piston should first check the time of day and then check the date. At 30 minutes to sunset, it should start cycling through the list of colors until midnight. I have adjusted the time and date range for it to run now. I know there is a more efficient way to have it cycle through the colors but I’m learning and haven’t figured it out yet.
All of the time and date checks are showing false in the logs.
11/19/2019, 9:38:59 AM +108ms
+1ms ╔Received event [Home].time = 1574174340000 with a delay of -892ms
+290ms ║RunTime Analysis CS > 22ms > PS > 240ms > PE > 28ms > CE
+293ms ║Runtime (46389 bytes) successfully initialized in 240ms (v0.3.110.20191009) (292ms)
+294ms ║╔Execution stage started
+309ms ║║Comparison (time) 34739407 is_between (time) 34740000 .. (time) 1574139600000 = true (7ms)
+310ms ║║Time restriction check passed
+312ms ║║Cancelling condition #34's schedules...
+312ms ║║Condition #34 evaluated true (13ms)
+313ms ║║Cancelling statement #34's schedules...
+320ms ║║Requesting time schedule wake up at Wed, Nov 20 2019 @ 12:00:00 AM EST
+322ms ║║Cancelling condition #33's schedules...
+323ms ║║Condition group #33 evaluated true (state changed) (24ms)
+331ms ║║Calculating (string) 07/04/ + (string) 2019 >> (string) 07/04/2019
+336ms ║║Calculating (decimal) 0.0 - (decimal) 7.0 >> (decimal) -7.0
+343ms ║║Calculating (string) 07/04/ + (string) 2019 >> (string) 07/04/2019
+350ms ║║Comparison (date) 1574139600000 is_between (datetime) 1561608000000 .. (datetime) 1562299200000 = false (4ms)
+352ms ║║Condition #38 evaluated false (26ms)
+357ms ║║Cancelling statement #38's schedules...
+364ms ║║Calculating (string) 07/04/ + (string) 2019 >> (string) 07/04/2019
+369ms ║║Calculating (decimal) 0.0 - (decimal) 7.0 >> (decimal) -7.0
+378ms ║║Calculating (string) 07/04/ + (string) 2019 >> (string) 07/04/2019
+383ms ║║Condition group #35 evaluated false (state did not change) (58ms)
+391ms ║║Calculating (string) 10/01/ + (string) 2019 >> (string) 10/01/2019
+399ms ║║Calculating (string) 10/31/ + (string) 2019 >> (string) 10/31/2019
+406ms ║║Comparison (date) 1574139600000 is_between (datetime) 6512360418207478181 .. (datetime) 1572580800000 = false (4ms)
+407ms ║║Condition #39 evaluated false (23ms)
+408ms ║║Cancelling statement #39's schedules...
+415ms ║║Calculating (string) 10/01/ + (string) 2019 >> (string) 10/01/2019
+424ms ║║Calculating (string) 10/31/ + (string) 2019 >> (string) 10/31/2019
+429ms ║║Requesting time schedule wake up at Tue, May 9 206370456 @ 5:37:58 AM EDT
+431ms ║║Condition group #36 evaluated false (state did not change) (48ms)
+438ms ║║Calculating (string) 11/01/ + (string) 2019 >> (string) 11/01/2019
+446ms ║║Calculating (string) 12/31/ + (string) 2019 >> (string) 12/31/2019
+452ms ║║Comparison (date) 1574139600000 is_between (datetime) 6743774178207478229 .. (datetime) 7191982818207478237 = false (4ms)
+454ms ║║Condition #51 evaluated false (22ms)
+455ms ║║Cancelling statement #51's schedules...
+461ms ║║Calculating (string) 11/01/ + (string) 2019 >> (string) 11/01/2019
+470ms ║║Calculating (string) 12/31/ + (string) 2019 >> (string) 12/31/2019
+474ms ║║Requesting time schedule wake up at Fri, Jun 25 213703666 @ 5:37:58 AM EDT
+476ms ║║Condition group #37 evaluated false (state did not change) (45ms)
+481ms ║╚Execution stage complete. (187ms)
+483ms ║Setting up scheduled job for Wed, Nov 20 2019 @ 12:00:00 AM EST (in 51660.409s), with 5 more jobs pending
+491ms ╚Event processed successfully (491ms)
