Hello.
In your piston, notice the lightning bolt in the left margin next to “Sensor 6’s humidity”.  This means the only time the piston will execute is when the device reports a change in the humidity.  At that point, the piston will run top to bottom.
That being said, the general structure of a piston is usually something like this:
IF X happens
    Do Y
END IF
(notice I did not use “WHEN TRUE” or “WHEN FALSE”)
To help with the extra clutter, I recommend programming with only two check-marks in the Options:
I would uncheck all of the rest.
99% of pistons do not need them, and they tend to confuse more than help…
Here is a double block piston that may do what you wish:
IF Sensor 6's humidity RISES ABOVE 75
    Turn on Exhaust fan
END IF
IF Sensor 6's humidity DROPS BELOW 70
    Turn off Exhaust fan
END IF
(notice I left a gap between the two numbers!)
Alternatively, if you would rather the shutoff be time based, this single block works:
Then with Exhaust Fan (TCP set to Never)
    Turn on
    Wait 10 minutes
    Turn off
END IF
This one turns off 10 minutes later, regardless of the current humidity.
