Hello. This is my first piston. All I’m trying to do is turn on a smartplug whenever one of my Ecobee sensors is equal or less than a specific temperature. I set it up so it runs every 30 minutes but when I run the TEST, it doesn’t turn on the smartplug even if the temperature condition is met.
It should turn on the smartplug.
It’s not turning on the smartplug
11/30/2018, 8:33:03 PM +906ms
+1ms ╔Received event [South SF].test = 1543638783905 with a delay of 1ms
+75ms ║RunTime Analysis CS > 14ms > PS > 39ms > PE > 21ms > CE
+78ms ║Runtime (36893 bytes) successfully initialized in 39ms (v0.3.108.20180906) (76ms)
+125ms ║╚Execution stage complete. (45ms)
+129ms ║Setting up scheduled job for Fri, Nov 30 2018 @ 11:02:19 PM PST (in 8955.406s)
+139ms ╚Event processed successfully (138ms)
