When turning on or off the switch manually during or outside of the “on” timeframe the switch will constantly cycle on/off… My goal is to have an outlet controlled by this piston and have it “correct” itself in the event of a power outage when it’s supposed to be on/off. ie: power comes back on, piston checks time, sets the switch accordingly if it needs to be changed. I’m sure there’s a better way to do this.
If the device is on during timeframe, and I turn it off, I want it to simply turn back on within 10 seconds of it being off. If it is off outside of this timeframe and I turn it on manually, I want it to turn itself off again within 10 seconds.
The outlet powers on and off repeatedly. Before adding the 10 second wait it would do it repeatedly without a pause on/off/on/off/on/off.
7/28/2020, 12:43:01 PM +922ms
+107ms ╔Stopping piston...
+181ms ╚Piston successfully stopped (75ms)
7/28/2020, 12:42:57 PM +622ms
+1ms ╔Received event [Outlet 2].switch = on with a delay of 49ms
+112ms ║RunTime Analysis CS > 21ms > PS > 54ms > PE > 38ms > CE
+115ms ║Runtime (37478 bytes) successfully initialized in 54ms (v0.3.110.20191009) (112ms)
+116ms ║╔Execution stage started
+123ms ║║Comparison (enum) on is_not (string) on = false (1ms)
+124ms ║║Cancelling condition #7's schedules...
+125ms ║║Condition #7 evaluated false (6ms)
+126ms ║║Cancelling condition #1's schedules...
+127ms ║║Condition group #1 evaluated false (state changed) (8ms)
+129ms ║║Cancelling statement #3's schedules...
+134ms ║║Executed virtual command [Outlet 2].wait (0ms)
+135ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:43:07 PM PDT (in 10.0s)
+139ms ║╚Execution stage complete. (24ms)
+141ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:43:07 PM PDT (in 9.995s), with 1 more job pending
+250ms ╚Event processed successfully (249ms)
7/28/2020, 12:42:57 PM +40ms
+1ms ╔Received event [Home].time = 1595965378749 with a delay of -1709ms
+105ms ║RunTime Analysis CS > 19ms > PS > 54ms > PE > 32ms > CE
+108ms ║Runtime (37486 bytes) successfully initialized in 54ms (v0.3.110.20191009) (105ms)
+290ms ║║Executed physical command [Outlet 2].on() (170ms)
+291ms ║║Executed [Outlet 2].on (172ms)
+294ms ║╚Execution stage complete. (186ms)
+296ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29822.665s)
+315ms ╚Event processed successfully (315ms)
7/28/2020, 12:42:48 PM +596ms
+2ms ╔Received event [Outlet 2].switch = off with a delay of 53ms
+111ms ║RunTime Analysis CS > 21ms > PS > 53ms > PE > 36ms > CE
+113ms ║Runtime (37483 bytes) successfully initialized in 53ms (v0.3.110.20191009) (111ms)
+122ms ║║Comparison (enum) off is_not (string) on = true (2ms)
+123ms ║║Cancelling condition #7's schedules...
+124ms ║║Condition #7 evaluated true (6ms)
+133ms ║║Comparison (time) 45768721 is_between (time) 21600000 .. (time) 75600000 = true (6ms)
+134ms ║║Time restriction check passed
+136ms ║║Condition #8 evaluated true (11ms)
+137ms ║║Cancelling statement #8's schedules...
+141ms ║║Requesting time schedule wake up at Tue, Jul 28 2020 @ 9:00:00 PM PDT
+143ms ║║Cancelling condition #1's schedules...
+144ms ║║Condition group #1 evaluated true (state changed) (26ms)
+146ms ║║Cancelling statement #5's schedules...
+151ms ║║Executed virtual command [Outlet 2].wait (1ms)
+152ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:42:58 PM PDT (in 10.0s)
+156ms ║╚Execution stage complete. (42ms)
+158ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:42:58 PM PDT (in 9.996s), with 1 more job pending
+176ms ╚Event processed successfully (176ms)
7/28/2020, 12:42:48 PM +64ms
+0ms ╔Received event [Home].time = 1595965369947 with a delay of -1884ms
+119ms ║RunTime Analysis CS > 28ms > PS > 60ms > PE > 32ms > CE
+122ms ║Runtime (37490 bytes) successfully initialized in 60ms (v0.3.110.20191009) (121ms)
+123ms ║╔Execution stage started
+286ms ║║Executed physical command [Outlet 2].off() (149ms)
+287ms ║║Executed [Outlet 2].off (151ms)
+290ms ║╚Execution stage complete. (168ms)
+292ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29831.645s)
7/28/2020, 12:42:39 PM +815ms
+1ms ╔Received event [Outlet 2].switch = on with a delay of 52ms
+108ms ║RunTime Analysis CS > 20ms > PS > 52ms > PE > 36ms > CE
+110ms ║Runtime (37478 bytes) successfully initialized in 52ms (v0.3.110.20191009) (108ms)
+111ms ║╔Execution stage started
+119ms ║║Comparison (enum) on is_not (string) on = false (2ms)
+120ms ║║Cancelling condition #7's schedules...
+121ms ║║Condition #7 evaluated false (6ms)
+122ms ║║Cancelling condition #1's schedules...
+123ms ║║Condition group #1 evaluated false (state changed) (8ms)
+125ms ║║Cancelling statement #3's schedules...
+130ms ║║Executed virtual command [Outlet 2].wait (0ms)
+131ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:42:49 PM PDT (in 10.0s)
+135ms ║╚Execution stage complete. (24ms)
+137ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:42:49 PM PDT (in 9.996s), with 1 more job pending
+155ms ╚Event processed successfully (155ms)
7/28/2020, 12:42:39 PM +56ms
+0ms ╔Received event [Home].time = 1595965360787 with a delay of -1732ms
+108ms ║RunTime Analysis CS > 20ms > PS > 57ms > PE > 32ms > CE
+110ms ║Runtime (37486 bytes) successfully initialized in 57ms (v0.3.110.20191009) (109ms)
+468ms ║║Executed physical command [Outlet 2].on() (333ms)
+469ms ║║Executed [Outlet 2].on (335ms)
+471ms ║╚Execution stage complete. (360ms)
+473ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29840.472s)
+489ms ╚Event processed successfully (488ms)
7/28/2020, 12:42:30 PM +624ms
+2ms ╔Received event [Outlet 2].switch = off with a delay of 55ms
+117ms ║RunTime Analysis CS > 24ms > PS > 58ms > PE > 35ms > CE
+120ms ║Runtime (37483 bytes) successfully initialized in 58ms (v0.3.110.20191009) (117ms)
+129ms ║║Comparison (enum) off is_not (string) on = true (1ms)
+131ms ║║Cancelling condition #7's schedules...
+132ms ║║Condition #7 evaluated true (7ms)
+142ms ║║Comparison (time) 45750757 is_between (time) 21600000 .. (time) 75600000 = true (6ms)
+143ms ║║Time restriction check passed
+145ms ║║Condition #8 evaluated true (11ms)
+146ms ║║Cancelling statement #8's schedules...
+150ms ║║Requesting time schedule wake up at Tue, Jul 28 2020 @ 9:00:00 PM PDT
+153ms ║║Cancelling condition #1's schedules...
+154ms ║║Condition group #1 evaluated true (state changed) (28ms)
+156ms ║║Cancelling statement #5's schedules...
+161ms ║║Executed virtual command [Outlet 2].wait (0ms)
+162ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:42:40 PM PDT (in 10.0s)
+167ms ║╚Execution stage complete. (45ms)
+168ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:42:40 PM PDT (in 9.995s), with 1 more job pending
+197ms ╚Event processed successfully (197ms)
7/28/2020, 12:42:30 PM +155ms
+1ms ╔Received event [Home].time = 1595965351824 with a delay of -1669ms
+113ms ║RunTime Analysis CS > 19ms > PS > 63ms > PE > 31ms > CE
+116ms ║Runtime (37490 bytes) successfully initialized in 63ms (v0.3.110.20191009) (115ms)
+117ms ║╔Execution stage started
+178ms ║║Executed physical command [Outlet 2].off() (46ms)
+179ms ║║Executed [Outlet 2].off (48ms)
+182ms ║╚Execution stage complete. (65ms)
+183ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29849.662s)
+217ms ╚Event processed successfully (217ms)
7/28/2020, 12:42:21 PM +693ms
+1ms ╔Received event [Outlet 2].switch = on with a delay of 51ms
+108ms ║RunTime Analysis CS > 20ms > PS > 55ms > PE > 33ms > CE
+111ms ║Runtime (37478 bytes) successfully initialized in 55ms (v0.3.110.20191009) (108ms)
+119ms ║║Comparison (enum) on is_not (string) on = false (1ms)
+121ms ║║Condition #7 evaluated false (5ms)
+131ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:42:31 PM PDT (in 10.0s)
+137ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:42:31 PM PDT (in 9.995s), with 1 more job pending
+150ms ╚Event processed successfully (149ms)
7/28/2020, 12:42:21 PM +228ms
+1ms ╔Received event [Home].time = 1595965342969 with a delay of -1741ms
+127ms ║RunTime Analysis CS > 22ms > PS > 76ms > PE > 29ms > CE
+130ms ║Runtime (37486 bytes) successfully initialized in 76ms (v0.3.110.20191009) (127ms)
+166ms ║║Executed physical command [Outlet 2].on() (23ms)
+167ms ║║Executed [Outlet 2].on (26ms)
+169ms ║╚Execution stage complete. (39ms)
+171ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29858.602s)
+179ms ╚Event processed successfully (179ms)
7/28/2020, 12:42:12 PM +813ms
+1ms ╔Received event [Outlet 2].switch = off with a delay of 55ms
+113ms ║RunTime Analysis CS > 19ms > PS > 54ms > PE > 40ms > CE
+116ms ║Runtime (37483 bytes) successfully initialized in 54ms (v0.3.110.20191009) (113ms)
+125ms ║║Comparison (enum) off is_not (string) on = true (1ms)
+126ms ║║Cancelling condition #7's schedules...
+127ms ║║Condition #7 evaluated true (6ms)
+137ms ║║Comparison (time) 45732941 is_between (time) 21600000 .. (time) 75600000 = true (6ms)
+138ms ║║Time restriction check passed
+139ms ║║Condition #8 evaluated true (11ms)
+140ms ║║Cancelling statement #8's schedules...
+145ms ║║Requesting time schedule wake up at Tue, Jul 28 2020 @ 9:00:00 PM PDT
+147ms ║║Cancelling condition #1's schedules...
+148ms ║║Condition group #1 evaluated true (state changed) (27ms)
+150ms ║║Cancelling statement #5's schedules...
+155ms ║║Executed virtual command [Outlet 2].wait (0ms)
+156ms ║║Requesting a wake up for Tue, Jul 28 2020 @ 12:42:22 PM PDT (in 10.0s)
+160ms ║╚Execution stage complete. (44ms)
+162ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 12:42:22 PM PDT (in 9.995s), with 1 more job pending
+195ms ╚Event processed successfully (195ms)
7/28/2020, 12:40:35 PM +631ms
+1ms ╔Starting piston... (v0.3.110.20191009)
+289ms ║╔Subscribing to devices...
+319ms ║║Subscribing to Outlet 2.switch...
+400ms ║╚Finished subscribing (116ms)
+425ms ║Comparison (enum) on is_not (string) on = false (2ms)
+437ms ║Comparison (time) 45636058 is_between (time) 21600000 .. (time) 75600000 = true (8ms)
+438ms ║Time restriction check passed
+442ms ║Cancelling statement #8's schedules...
+447ms ║Requesting time schedule wake up at Tue, Jul 28 2020 @ 9:00:00 PM PDT
+466ms ║Setting up scheduled job for Tue, Jul 28 2020 @ 9:00:00 PM PDT (in 29963.903s)
+491ms ╚Piston successfully started (491ms)
, had it paused from the previous troubleshooting. I’ll report back if I have other issues.
