Socket stays on when it should not
At 20 minutes before Sunset every day, the device turns on. At 10:30pm every day, the device turns off.
The device is not turning off.
6/28/2020, 10:29:59 PM +76ms
+1ms ╔Received event [Home].time = 1593397800000 with a delay of -924ms
+91ms ║RunTime Analysis CS > 22ms > PS > 47ms > PE > 22ms > CE
+94ms ║Runtime (36546 bytes) successfully initialized in 47ms (v0.3.110.20191009) (92ms)
+127ms ║║Comparison (time) 80999175 is_between (datetime) 1593390780000 .. (time) 81000000 = false (7ms)
+128ms ║║Cancelling condition #2's schedules...
+129ms ║║Condition #2 evaluated false (30ms)
+130ms ║║Cancelling statement #2's schedules...
+135ms ║║Requesting time schedule wake up at Mon, Jun 29 2020 @ 8:13:00 PM EDT
+137ms ║║Cancelling condition #1's schedules...
+138ms ║║Condition group #1 evaluated false (state changed) (40ms)
+140ms ║║Cancelling statement #3's schedules...
+152ms ║║Executed physical command [Basement Door Socket].off() (8ms)
+152ms ║║Executed [Basement Door Socket].off (9ms)
+155ms ║╚Execution stage complete. (61ms)
+156ms ║Setting up scheduled job for Mon, Jun 29 2020 @ 8:13:00 PM EDT (in 78180.769s)
+162ms ╚Event processed successfully (162ms)
6/28/2020, 8:12:59 PM +152ms
+1ms ╔Received event [Home].time = 1593389580000 with a delay of -848ms
+121ms ║RunTime Analysis CS > 32ms > PS > 48ms > PE > 41ms > CE
+124ms ║Runtime (36552 bytes) successfully initialized in 48ms (v0.3.110.20191009) (122ms)
+170ms ║║Comparison (time) 72779284 is_between (datetime) 1593390780000 .. (time) 81000000 = true (10ms)
+172ms ║║Time restriction check passed
+174ms ║║Cancelling condition #2's schedules...
+175ms ║║Condition #2 evaluated true (44ms)
+176ms ║║Cancelling statement #2's schedules...
+183ms ║║Requesting time schedule wake up at Sun, Jun 28 2020 @ 10:30:00 PM EDT
+186ms ║║Cancelling condition #1's schedules...
+188ms ║║Condition group #1 evaluated true (state changed) (56ms)
+191ms ║║Cancelling statement #5's schedules...
+206ms ║║Executed physical command [Basement Door Socket].on() (12ms)
+207ms ║║Executed [Basement Door Socket].on (14ms)
+209ms ║╚Execution stage complete. (84ms)
+211ms ║Setting up scheduled job for Sun, Jun 28 2020 @ 10:30:00 PM EDT (in 8220.638s)
+220ms ╚Event processed successfully (219ms)
6/27/2020, 10:29:59 PM +81ms
+0ms ╔Received event [Home].time = 1593311400000 with a delay of -920ms
+102ms ║RunTime Analysis CS > 23ms > PS > 54ms > PE > 26ms > CE
+104ms ║Runtime (36547 bytes) successfully initialized in 54ms (v0.3.110.20191009) (103ms)
+139ms ║║Comparison (time) 80999191 is_between (datetime) 1593304380000 .. (time) 81000000 = false (6ms)
+141ms ║║Cancelling condition #2's schedules...
+142ms ║║Condition #2 evaluated false (32ms)
+143ms ║║Cancelling statement #2's schedules...
+148ms ║║Requesting time schedule wake up at Sun, Jun 28 2020 @ 8:13:00 PM EDT
+150ms ║║Cancelling condition #1's schedules...
+151ms ║║Condition group #1 evaluated false (state changed) (41ms)
+152ms ║║Cancelling statement #3's schedules...
+167ms ║║Executed physical command [Basement Door Socket].off() (10ms)
+168ms ║║Executed [Basement Door Socket].off (12ms)
+170ms ║╚Execution stage complete. (65ms)
+171ms ║Setting up scheduled job for Sun, Jun 28 2020 @ 8:13:00 PM EDT (in 78180.748s)
+177ms ╚Event processed successfully (178ms)
6/27/2020, 8:12:59 PM +87ms
+0ms ╔Received event [Home].time = 1593303180000 with a delay of -913ms
+71ms ║RunTime Analysis CS > 18ms > PS > 28ms > PE > 25ms > CE
+73ms ║Runtime (36551 bytes) successfully initialized in 28ms (v0.3.110.20191009) (72ms)
+105ms ║║Comparison (time) 72779166 is_between (datetime) 1593304380000 .. (time) 81000000 = true (6ms)
+106ms ║║Time restriction check passed
+107ms ║║Cancelling condition #2's schedules...
+108ms ║║Condition #2 evaluated true (30ms)
+109ms ║║Cancelling statement #2's schedules...
+114ms ║║Requesting time schedule wake up at Sat, Jun 27 2020 @ 10:30:00 PM EDT
+116ms ║║Cancelling condition #1's schedules...
+117ms ║║Condition group #1 evaluated true (state changed) (39ms)
+119ms ║║Cancelling statement #5's schedules...
+130ms ║║Executed physical command [Basement Door Socket].on() (8ms)
+131ms ║║Executed [Basement Door Socket].on (10ms)
+133ms ║╚Execution stage complete. (59ms)
+134ms ║Setting up scheduled job for Sat, Jun 27 2020 @ 10:30:00 PM EDT (in 8220.779s)
+141ms ╚Event processed successfully (141ms)
6/26/2020, 10:29:59 PM +100ms
+0ms ╔Received event [Home].time = 1593225000000 with a delay of -900ms
+114ms ║RunTime Analysis CS > 28ms > PS > 52ms > PE > 33ms > CE
+116ms ║Runtime (36547 bytes) successfully initialized in 52ms (v0.3.110.20191009) (115ms)
+117ms ║╔Execution stage started
+154ms ║║Comparison (time) 80999222 is_between (datetime) 1593217980000 .. (time) 81000000 = false (7ms)
+155ms ║║Cancelling condition #2's schedules...
+156ms ║║Condition #2 evaluated false (34ms)
+157ms ║║Cancelling statement #2's schedules...
+164ms ║║Requesting time schedule wake up at Sat, Jun 27 2020 @ 8:13:00 PM EDT
+166ms ║║Cancelling condition #1's schedules...
+167ms ║║Condition group #1 evaluated false (state changed) (44ms)
+168ms ║║Cancelling statement #3's schedules...
+183ms ║║Executed physical command [Basement Door Socket].off() (12ms)
+184ms ║║Executed [Basement Door Socket].off (14ms)
+187ms ║╚Execution stage complete. (70ms)
+189ms ║Setting up scheduled job for Sat, Jun 27 2020 @ 8:13:00 PM EDT (in 78180.712s)
+198ms ╚Event processed successfully (198ms)
6/26/2020, 8:12:59 PM +86ms
+0ms ╔Received event [Home].time = 1593216780000 with a delay of -914ms
+76ms ║RunTime Analysis CS > 18ms > PS > 31ms > PE > 27ms > CE
+78ms ║Runtime (36551 bytes) successfully initialized in 31ms (v0.3.110.20191009) (77ms)
+113ms ║║Comparison (time) 72779170 is_between (datetime) 1593217980000 .. (time) 81000000 = true (6ms)
+114ms ║║Time restriction check passed
+115ms ║║Cancelling condition #2's schedules...
+116ms ║║Condition #2 evaluated true (32ms)
+117ms ║║Cancelling statement #2's schedules...
+123ms ║║Requesting time schedule wake up at Fri, Jun 26 2020 @ 10:30:00 PM EDT
+125ms ║║Cancelling condition #1's schedules...
+126ms ║║Condition group #1 evaluated true (state changed) (42ms)
+128ms ║║Cancelling statement #5's schedules...
+138ms ║║Executed physical command [Basement Door Socket].on() (7ms)
+139ms ║║Executed [Basement Door Socket].on (9ms)
+141ms ║╚Execution stage complete. (62ms)
+143ms ║Setting up scheduled job for Fri, Jun 26 2020 @ 10:30:00 PM EDT (in 8220.772s)
+152ms ╚Event processed successfully (152ms)
6/25/2020, 10:29:59 PM +63ms
+1ms ╔Received event [Home].time = 1593138600000 with a delay of -937ms
+79ms ║RunTime Analysis CS > 22ms > PS > 34ms > PE > 22ms > CE
+81ms ║Runtime (36546 bytes) successfully initialized in 34ms (v0.3.110.20191009) (79ms)
+124ms ║║Comparison (time) 80999151 is_between (datetime) 1593131580000 .. (time) 81000000 = false (10ms)
+126ms ║║Cancelling condition #2's schedules...
+128ms ║║Condition #2 evaluated false (40ms)
+140ms ║║Requesting time schedule wake up at Fri, Jun 26 2020 @ 8:13:00 PM EDT
+143ms ║║Cancelling condition #1's schedules...
+145ms ║║Condition group #1 evaluated false (state changed) (57ms)
+148ms ║║Cancelling statement #3's schedules...
+163ms ║║Executed physical command [Basement Door Socket].off() (9ms)
+164ms ║║Executed [Basement Door Socket].off (13ms)
+170ms ║╚Execution stage complete. (87ms)
+172ms ║Setting up scheduled job for Fri, Jun 26 2020 @ 8:13:00 PM EDT (in 78180.766s)
+183ms ╚Event processed successfully (183ms)
6/25/2020, 8:12:59 PM +101ms
+1ms ╔Received event [Home].time = 1593130380000 with a delay of -900ms
+116ms ║RunTime Analysis CS > 27ms > PS > 60ms > PE > 29ms > CE
+119ms ║Runtime (36552 bytes) successfully initialized in 60ms (v0.3.110.20191009) (117ms)
+164ms ║║Comparison (time) 72779229 is_between (datetime) 1593131580000 .. (time) 81000000 = true (9ms)
+165ms ║║Time restriction check passed
+166ms ║║Cancelling condition #2's schedules...
+167ms ║║Condition #2 evaluated true (39ms)
+168ms ║║Cancelling statement #2's schedules...
+174ms ║║Requesting time schedule wake up at Thu, Jun 25 2020 @ 10:30:00 PM EDT
+176ms ║║Cancelling condition #1's schedules...
+177ms ║║Condition group #1 evaluated true (state changed) (49ms)
+179ms ║║Cancelling statement #5's schedules...
+186ms ║║Skipped execution of physical command [Basement Door Socket].on([]) because it would make no change to the device. (3ms)
+187ms ║║Executed [Basement Door Socket].on (5ms)
+189ms ║╚Execution stage complete. (70ms)
+191ms ║Setting up scheduled job for Thu, Jun 25 2020 @ 10:30:00 PM EDT (in 8220.709s)
+322ms ╚Event processed successfully (322ms)
6/24/2020, 10:48:29 PM +243ms
+1ms ╔Received event [Home].execute = recovery with a delay of 62ms
+148ms ║RunTime Analysis CS > 23ms > PS > 95ms > PE > 29ms > CE
+150ms ║Runtime (36541 bytes) successfully initialized in 95ms (v0.3.110.20191009) (149ms)
+151ms ║╔Execution stage started
+189ms ║║Comparison (time) 82109398 is_between (datetime) 1593045180000 .. (time) 81000000 = false (7ms)
+191ms ║║Cancelling condition #2's schedules...
+192ms ║║Condition #2 evaluated false (36ms)
+193ms ║║Cancelling statement #2's schedules...
+198ms ║║Requesting time schedule wake up at Thu, Jun 25 2020 @ 8:13:00 PM EDT
+201ms ║║Cancelling condition #1's schedules...
+202ms ║║Condition group #1 evaluated false (state changed) (47ms)
+204ms ║║Cancelling statement #3's schedules...
+216ms ║║Executed physical command [Basement Door Socket].off() (9ms)
+217ms ║║Executed [Basement Door Socket].off (11ms)
+220ms ║╚Execution stage complete. (69ms)
+221ms ║Setting up scheduled job for Thu, Jun 25 2020 @ 8:13:00 PM EDT (in 77070.536s)
+229ms ╚Event processed successfully (228ms)
6/24/2020, 8:12:59 PM +123ms
+0ms ╔Received event [Home].time = 1593043980000 with a delay of -878ms
+148ms ║RunTime Analysis CS > 36ms > PS > 86ms > PE > 26ms > CE
+150ms ║Runtime (36550 bytes) successfully initialized in 86ms (v0.3.110.20191009) (149ms)
+201ms ║║Comparison (time) 72779279 is_between (datetime) 1593045180000 .. (time) 81000000 = true (6ms)
+203ms ║║Time restriction check passed
+204ms ║║Cancelling condition #2's schedules...
+205ms ║║Condition #2 evaluated true (49ms)
+206ms ║║Cancelling statement #2's schedules...
+212ms ║║Requesting time schedule wake up at Wed, Jun 24 2020 @ 10:30:00 PM EDT
+214ms ║║Cancelling condition #1's schedules...
+215ms ║║Condition group #1 evaluated true (state changed) (60ms)
+217ms ║║Cancelling statement #5's schedules...
+235ms ║║Executed physical command [Basement Door Socket].on() (12ms)
+236ms ║║Executed [Basement Door Socket].on (14ms)
+238ms ║╚Execution stage complete. (87ms)
+240ms ║Setting up scheduled job for Wed, Jun 24 2020 @ 10:30:00 PM EDT (in 8220.638s)
+248ms ╚Event processed successfully (248ms)
