Bathroom has 2 switches: light and fan. They could be turned on at different times so each has its own timer. Both are the same duration. Piston has 2 while loops, both wait 2 mins (testing timer), but when second event triggers, the first scheduled task executes and the second restarts the 2 minutes
Both timers expire and execute without restarting
The second trigger sets a scheduled event but restarts timer instead of firing
8/30/2022, 11:17:20 AM +525ms
+3ms ╔Received event [Pool Bath Fan].switch = off with a delay of 45ms, canQueue: true, calledMyself: false
+11ms ║RunTime initialize > 11 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 10 4 7)
+13ms ║Runtime (5986 bytes) initialized in 1ms (v0.3.114.20220822_HE)
+15ms ║╔Execution stage started
+18ms ║║Comparison (enum) off is (string) on = false (1ms)
+20ms ║║Condition #2 evaluated false (3ms)
+22ms ║║Canceling condition #1’s schedules…3 (st:4)
+23ms ║║Condition group #1 evaluated false (condition changed) (6ms)
+26ms ║║Comparison (enum) off is (string) on = false (0ms)
+27ms ║║Condition #7 evaluated false (3ms)
+27ms ║║Condition group #6 evaluated false (condition did not change) (4ms)
+31ms ║╚Execution stage complete. (17ms)
+42ms ╚Event processed successfully (39ms)
8/30/2022, 11:17:20 AM +39ms
+3ms ╔Received event [Cobalt].time = 1661883439997 with a delay of 42ms, canQueue: true, calledMyself: false
+13ms ║Runtime (5983 bytes) initialized in 1ms (v0.3.114.20220822_HE)
+19ms ║╔Execution stage started
+36ms ║║Executed physical command [Pool Bath Fan].off() (11ms)
+36ms ║║Executed [Pool Bath Fan].off (12ms)
+40ms ║║Comparison (enum) on is (string) on = true (1ms)
+41ms ║║Condition #2 evaluated true (4ms)
+42ms ║║Condition group #1 evaluated true (condition did not change) (5ms)
+48ms ║║Executed virtual command [Pool Bath Fan].wait (0ms)
+50ms ║║Requesting wake up at Tue, Aug 30 2022 @ 11:19:20 AM MST (in 119999ms) for 3 (st:4)
+55ms ║╚Execution stage complete. (35ms)
+76ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:19:20 AM MST (in 120021ms)
+78ms ╚Event processed successfully (75ms)
8/30/2022, 11:17:19 AM +560ms
+4ms ╔Received event [Cobalt].time = 1661883439518 with a delay of 42ms, canQueue: true, calledMyself: false
+12ms ║RunTime initialize > 12 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 9 5 7)
+14ms ║Runtime (5975 bytes) initialized in 2ms (v0.3.114.20220822_HE)
+20ms ║╔Execution stage started
+27ms ║║Skipped execution of physical command [Pool Bath Light].off([]) because it would make no change to the device. (1ms)
+28ms ║║Executed [Pool Bath Light].off (1ms)
+31ms ║║Comparison (enum) off is (string) on = false (0ms)
+32ms ║║Condition #7 evaluated false (3ms)
+34ms ║║Condition group #6 evaluated false (condition changed) (6ms)
+39ms ║╚Execution stage complete. (19ms)
+61ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:17:19 AM MST (in 426ms)
+63ms ╚Event processed successfully (59ms)
8/30/2022, 11:15:19 AM +971ms
+3ms ╔Received event [Pool Bath Light].switch = off with a delay of 47ms, canQueue: true, calledMyself: false
+11ms ║RunTime initialize > 10 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 9 3 7)
+13ms ║Runtime (5972 bytes) initialized in 1ms (v0.3.114.20220822_HE)
+14ms ║╔Execution stage started
+19ms ║║Comparison (enum) on is (string) on = true (1ms)
+20ms ║║Condition #2 evaluated true (3ms)
+20ms ║║Condition group #1 evaluated true (condition did not change) (4ms)
+23ms ║║Canceling statement #3’s schedules…3 (st:4)
+26ms ║║Executed virtual command [Pool Bath Fan].wait (0ms)
+28ms ║║Requesting wake up at Tue, Aug 30 2022 @ 11:17:19 AM MST (in 119999ms) for 3 (st:4)
+44ms ║╚Execution stage complete. (30ms)
+69ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:17:19 AM MST (in 119530ms),with 1 more job pending
+70ms ╚Event processed successfully (68ms)
8/30/2022, 11:15:19 AM +469ms
+5ms ╔Received event [Cobalt].time = 1661883319427 with a delay of 42ms, canQueue: true, calledMyself: false
+12ms ║RunTime initialize > 12 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 11 5 7)
+14ms ║Runtime (5967 bytes) initialized in 1ms (v0.3.114.20220822_HE)
+21ms ║╔Execution stage started
+38ms ║║Executed physical command [Pool Bath Light].off() (11ms)
+39ms ║║Executed [Pool Bath Light].off (12ms)
+42ms ║║Comparison (enum) on is (string) on = true (1ms)
+43ms ║║Condition #7 evaluated true (3ms)
+44ms ║║Condition group #6 evaluated true (condition did not change) (4ms)
+48ms ║║Executed virtual command [Pool Bath Light].wait (0ms)
+50ms ║║Requesting wake up at Tue, Aug 30 2022 @ 11:17:19 AM MST (in 119999ms) for 8 (st:9)
+56ms ║╚Execution stage complete. (35ms)
+82ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:15:36 AM MST (in 17412ms),with 1 more job pending
+84ms ╚Event processed successfully (79ms)
8/30/2022, 11:13:36 AM +883ms
+3ms ╔Received event [Pool Bath Fan].switch = on with a delay of 49ms, canQueue: true, calledMyself: false
+10ms ║RunTime initialize > 9 LockT > 1ms > r9T > 1ms > pistonT > 0ms (first state access 7 4 5)
+12ms ║Runtime (5952 bytes) initialized in 1ms (v0.3.114.20220822_HE)
+13ms ║╔Execution stage started
+17ms ║║Comparison (enum) on is (string) on = true (1ms)
+20ms ║║Condition #2 evaluated true (4ms)
+21ms ║║Condition group #1 evaluated true (condition changed) (6ms)
+28ms ║║Requesting wake up at Tue, Aug 30 2022 @ 11:15:36 AM MST (in 119999ms) for 3 (st:4)
+44ms ║╚Execution stage complete. (31ms)
+68ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:15:19 AM MST (in 102528ms),with 1 more job pending
+70ms ╚Event processed successfully (67ms)
8/30/2022, 11:13:19 AM +369ms
+3ms ╔Received event [Pool Bath Light].switch = on with a delay of 60ms, canQueue: true, calledMyself: false
+31ms ║RunTime initialize > 30 LockT > 0ms > r9T > 23ms > pistonT > 22ms (first state access 7 3 27)
+33ms ║Runtime (6007 bytes) initialized in 23ms (v0.3.114.20220822_HE)
+35ms ║╔Execution stage started
+43ms ║║Comparison (enum) off is (string) on = false (1ms)
+44ms ║║Condition #2 evaluated false (6ms)
+45ms ║║Condition group #1 evaluated false (condition did not change) (8ms)
+48ms ║║Comparison (enum) on is (string) on = true (0ms)
+51ms ║║Condition #7 evaluated true (4ms)
+52ms ║║Condition group #6 evaluated true (condition changed) (6ms)
+58ms ║║Executed virtual command [Pool Bath Light].wait (1ms)
+60ms ║║Requesting wake up at Tue, Aug 30 2022 @ 11:15:19 AM MST (in 119999ms) for 8 (st:9)
+68ms ║╚Execution stage complete. (35ms)
+94ms ║Setting up scheduled job for Tue, Aug 30 2022 @ 11:15:19 AM MST (in 120014ms)
+95ms ╚Event processed successfully (93ms)
8/30/2022, 11:13:06 AM +841ms
+163ms ╔Subscribing to devices…
+198ms ║Device missing from piston. Loading all from parent (31ms)
+206ms ║subscriptions: no triggers, promoting conditions
+207ms ║Subscribing to Pool Bath Fan.switch…
+327ms ║subscriptions: no triggers, promoting conditions
+328ms ║Subscribing to Pool Bath Light.switch…
+422ms ╚Finished subscribing (415ms)
+435ms ║Comparison (enum) off is (string) on = false (0ms)
+440ms ║Comparison (enum) off is (string) on = false (1ms)
+455ms ╔Starting piston… (v0.3.114.20220822_HE)
+456ms ╚Piston started (450ms)
Clear
Full
