Hi, my piston works fine but i know it can be simplifed. My Webcore skill level is low but i’m learning
so i have multiple IF blocks, each one tells Echo to say something different dependant on which door sensor is open. Is this possible without multiple IF blocks. Eg if sensor 1,2,3,4 or 5 is open then do Echo Voice command 1,2,3,4 or 5 depending on the door sensor which is open
As above
(upload://vkKPEwTA67HXhaJIX4FQ5KJRHdp.png)
