Simplifying multiple ‘copies’ of pistons using arrays?
Instead of having one of these pistons for each sensor…
… I’m wondering if this piston can be adapted to work for multiple sensors instead using an arrays?
I’m useless with arrays, and thus I tried and failed.
(upload://xK8WwMCzoDkDrcB1Jf27yjtZ9bq.png)**
n/a
Here are the two ‘devices’. They’re just a way to to store some info for use in dashboards. The first is for a single motion sensor, of which there will a number of these in various rooms on the same floor of the house. The second one is a way to illustrate the status of the floor as a whole, based on the most recent activity of any of the sensors on that floor. There’ll only be one of these. Whatever gets accomplished, I can just recreate as a separate instance with a fresh floor and it’s own set of sensors.
