I have given up on WC Presence Sensors. It works great on my wife’s phone but after 1 initial trigger on my phone it never triggers again whether WC app is open or not and I have all the battery optimization turned off and even disabled the Huawei powergenie thru adb. I also can’t use the Wi-Fi presence app because of very limited public wifi where I live and the app also does not recognize the WiFi NEAR concept.
So current exploration is using geo fences in tasker and passing data to WC and using a Simulated Presence Device. This also means no limits to geo fences and having to set up multiple WC instances to get past the 10 limit that is in WC.
I Set up several geo fences in Tasker/AutoLocation…all good and so far working well (which would seem to point to a problem in the WC app’s Presence Sensor).
I am passing 5 variables from Tasker to WC and they all arrive.
I am setting the simulated Presence Sensor to present/not present no problem.
First I set Variables based on the passed parameters from Tasker
Then I set Presence based on what CurrentPlace came in
Then I just test to make sure I can trigger on presence and that it was set correctly.
So then I decided to look into $ARGS to see what was in there as well as looking to see what happened with other things like $currentEventDevice…and that is when things started to look ‘interesting’.
I successfully passed the EventTime from tasker but it does not show up in $ARGS as the others do. Also before I added the EventTime, there seemed to be a proper order to passing the parameters from Tasker. A couple other variables were not showing up until I changed the order (so now Tasker Order = Definition order = Order I set/extracted them in the piston). Is there a method/sequence/??? that these parameters have to follow so show up in $ARGS when I write them to “somewhere” other than into a variable?
currentEventDevice = Home from some strange reason. It should be = Name = PresenceDevice
- Can I expect to use any of the currentEventDevice and related variables like previousEventDevice or statements like this:
…or do they only apply if I am using the WC Presence Sensor? I am still trying to sort out if these kind of things are only available because they are exposed by the Device Handler and how to know which of these device attributes I can inquire on or even if there are some I can set (probablly another separate question/topic).
And here is the tasker GET for the Enter Location task.
Enough questions for now…thanks in advance.
LEAVING
2/26/2020, 5:11:21 PM +503ms
+144ms ║Michael…Left…ARRIVED: Travelling …CAME FROM: Home…TIME: Wed, Feb 26 2020 @ 5:11:21 PM CST
+207ms ║Michael was set to Away: PRESENCE not present ARGS: [Action:Left, CurrentPlace:Travelling, Name:Michael, PreviousPlace:Home, param1:execute, param2::3520d3750b5c8c029a4748c5179528ae:, remoteAddr:xxx.xxx.xxx.xxx]
+241ms ║AWAY…PRESENCE: not present ARGS: [Action:Left, CurrentPlace:Travelling, Name:Michael, PreviousPlace:Home, param1:execute, param2::3520d3750b5c8c029a4748c5179528ae:, remoteAddr:xxx.xxx.xxx.xxx]
ARRIVING
2/26/2020, 5:10:08 PM +358ms
+776ms ║Michael…Arrived…ARRIVED: Home …CAME FROM: Home…TIME: Wed, Feb 26 2020 @ 5:10:08 PM CST
+925ms ║Michael was set to Arrived: PRESENCE present ARGS: [Action:Arrived, CurrentPlace:Home, Name:Michael, PreviousPlace:Home, param1:execute, param2::3520d3750b5c8c029a4748c5179528ae:, remoteAddr:xxx.xxx.xxx.xxx] CURRDEV: Home
+953ms ║ HOME…PRESENCE: present ARGS: [Action:Arrived, CurrentPlace:Home, Name:Michael, PreviousPlace:Home, param1:execute, param2::3520d3750b5c8c029a4748c5179528ae:, remoteAddr:xxx.xxx.xxx]
