The simulated switch isn’t turned off sometimes.
The piston is executed when the trigger is turned on and shall turn it off after 1 sec. again. (the switch is used in IFTTT to execute a comman there).
Sometimes it isn’t turned off.
**4) Post a Green Snapshot
20.2.2020, 10:24:50 +556ms
+1ms ╔Received event [Rollläden ST öffnen].switch = on with a delay of 152ms
+138ms ║RunTime Analysis CS > 19ms > PS > 102ms > PE > 16ms > CE
+140ms ║Runtime (38300 bytes) successfully initialized in 102ms (v0.3.110.20191009) (138ms)
+141ms ║╔Execution stage started
+149ms ║║Comparison (enum) on changes_to (string) on = false (0ms)
+151ms ║║Cancelling condition #2’s schedules…
+152ms ║║Condition #2 evaluated false (7ms)
+153ms ║║Cancelling condition #1’s schedules…
+154ms ║║Condition group #1 evaluated false (state changed) (8ms)
+156ms ║╚Execution stage complete. (15ms)
+157ms ╚Event processed successfully (157ms)
20.2.2020, 10:24:42 +968ms
+1ms ╔Received event [Rollläden ST öffnen].switch = off with a delay of 93ms
+123ms ║RunTime Analysis CS > 26ms > PS > 83ms > PE > 14ms > CE
+125ms ║Runtime (38304 bytes) successfully initialized in 83ms (v0.3.110.20191009) (124ms)
+133ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+134ms ║║Condition #2 evaluated false (4ms)
+135ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+137ms ║╚Execution stage complete. (12ms)
+138ms ╚Event processed successfully (138ms)
20.2.2020, 10:24:41 +686ms
+1ms ╔Received event [Rollläden ST öffnen].switch = on with a delay of 151ms
+140ms ║RunTime Analysis CS > 20ms > PS > 106ms > PE > 15ms > CE
+143ms ║Runtime (38306 bytes) successfully initialized in 106ms (v0.3.110.20191009) (141ms)
+151ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+152ms ║║Cancelling condition #2’s schedules…
+153ms ║║Condition #2 evaluated true (5ms)
+154ms ║║Cancelling condition #1’s schedules…
+155ms ║║Condition group #1 evaluated true (state changed) (8ms)
+157ms ║║Cancelling statement #3’s schedules…
+160ms ║║Executed virtual command wait (1ms)
+161ms ║║Waiting for 1000ms
+1164ms ║║Cancelling statement #5’s schedules…
+1204ms ║║Executed physical command [Rollläden ST öffnen].off() (37ms)
+1205ms ║║Executed [Rollläden ST öffnen].off (39ms)
+1207ms ║╚Execution stage complete. (1064ms)
+1208ms ╚Event processed successfully (1208ms)
